โJul-16-2019 08:47 AM
โJul-19-2019 07:26 AM
mikemc53 wrote:
Thanks, much! Does the 5 button just pull out by hand, or is there usually some type of disconnect somewhere?
โJul-19-2019 07:11 AM
โJul-19-2019 05:27 AM
โJul-18-2019 12:33 PM
mikemc53 wrote:
Well, it does appear to be the tstat sensor and, yes, it is set up like the older Monacos that you mentioned. Right up front under the TV box and very close to the gigantic heat conducting windshield. I made sure I closed the curtains and it really helped but I will probably put some reflectix behind the curtains. Is there an easy way to move the sensor? The wiring is all hidden and I wouldn't be clear as to where to route things. Maybe a wireless sensor?
โJul-18-2019 12:32 PM
โJul-18-2019 11:45 AM
โJul-16-2019 09:29 AM
โJul-16-2019 09:25 AM
