AC motor fan
T_bone1
A few days ago the fan on front AC didn't want to go..I went on top and gave it help and it has worked fairly well until about 5 AM today..Fan motor stopped and compressor kept going..so I turned it off.....After a few minutes I turned it back on and it fired right off...for about 20 minutes! It will come on now and run for a while and the fan shuts off. I am thinking I need to replace the motor..Doesn't look like too difficult of a job. Any and all suggestions are appreciated. Thanks,Terry.
2017 Georgetown 329S
2015 Toyota Tacoma toad
12 REPLIES 12
Learjet
wa8yxm wrote:
Some units have a single cap that is both Start AND RUn but there is always a Start Cap. or so says ELI the ICE man.. if you know who that is. or rather what that is. you know WHY there is always a cap.. Sometimes there are 2 of 'em.
Do you mean to say there is always a run capacitor and sometimes a start capacitor for the compressor? I believe this is correct.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
wa8yxm
badsix
check Amazon
Jay D.
T_bone1
Mine is a Dometic BRisk Air 2
BMCM
PPL Motorhomes is showing a start/run capacitor for Coleman AC's, $25 until 9-21-18, plus $10
shipping.
Guessing it's not Coleman specific?
F-350, Scorpion, QC, Dually/Alpenleak
All Gave Some,
Some Gave All.
BMCM
In my Coleman Mach III (RVP), there is a start AND run capacitor.
AC stopped working 2 days ago. At the point I am going to try the
capacitor(s) first, if I can find them.
All Gave Some,
Some Gave All.
Boon_Docker
If the motor is starting then the capacitor is OK. The capacitor is only needed to start the motor. When it runs for a while then slows down sounds more like a bearing issue.
T_bone1
Are the capacitors mainly for starting? It will now start and run for a while and then slow down and quit..Thanks for the replies.Can someone give me some guidance on which capacitor to pick up.?
Darryl_Rita
Lube the motor, assuming it's never been done. Too many times, this basic maintenance gets missed.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
wa8yxm
Larry I like your tag line.
I too woudl do the Cap's (Start if you have one and run capacitors) first. THEN if it is still a problem the motor.. Only in my case I might do the motor first since I carry a spare.. But.. not everyone has one (I have 2) of those ๐Ÿ™‚
NOTE this has worked out well in the past for others. Had a man with a cracked blower assembly... Not much chance of getting a new one for like 3 days.. Except I had a spare :).
larry_cad
Just changed the fan motor on mine. Took about an hour.
Today is my personal best for most consecutive days alive.
Our Travel Blog
folivier
Change the capacitors first, that's likely the problem and much cheaper and easier.
