Adding a dedicated RV power plug. What would you do?
TurnThePage
I'm finally adding central air to my house, which affords me an opportunity to also wire in dedicated RV power.
Their price for a basic 30 amp wall plug install is very reasonable, but I'm considering going for the gusto and getting a box with 50/30/20 and breakers. I don't need 50 amp service, but it might be good to have for possible but doubtful upgrades, and maybe it will add a little value to the homestead when I get around to selling.
I'm assuming those boxes, which are expensive, must be already internally wired and simply need to be connected to a source. Is that correct? Does anybody ever NEED 50 amp to their RV when at home? And does anybody know if the 30 amp and 20 amp are on the same leg (in phase)?
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
39 REPLIES 39
allen8106
I don't "need" 50 amps but I did install a 50 amp outlet just in case. It's much nicer mucking around inside the 5ver when I can turn on the AC and sty cool. I rather have and not need than need it and not have it!
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
TurnThePage
Thanks all!
2015 Ram 1500
wolfe10
TurnThePage wrote:
It's my understanding that 240v is simply two 120v legs that are 180 degrees out of phase.
This is correct. Don't let semantics confuse you.
The 50 amp outlet will be exactly like a house-type stove/oven outlet: 2 hots to the outer straights, neutral to center straight and ground to center round.
The 30 will NOT be the same as a house-type 30 amp. It will have ONE hot, a neutral and a ground.
The 20 amp will be the same as the house-type with one hot, one neutral and a ground.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
time2roll
No. Power in the USA is either single phase or 3-phase. You do not have 3-phase at home.
Transformer that produces 240 volts has a center tap. Each hot has 120v to the center tap (neutral) and 240 volts to each other. A better term is 'split phase'. Still it is single phase power.
The word 'phase' has two different meanings that get crossed up with alternating current. The two meanings have to do with phase shift and frequency. wiki explains it better than I will here.
TurnThePage
I'm leaning toward the 20/30/50 install. I'm not an electrician but know enough to be dangerous. And, no I'm not doing my own install but really want to understand the one thing that keeps popping up in the descriptions, "single phase". It's my understanding that 240v is simply two 120v legs that are 180 degrees out of phase. Doesn't that mean "2 phase"?
2015 Ram 1500
2manytoyz
I installed a 30A outlet on my house when I moved in, and already owned a 25' TT. I've since purchased a 35' Class A, which uses 50A. I'm currently using a 30A to 50A adapter.
I recently purchased a 50A breaker from my local Home Depot. Took an old breaker with me to make sure I got the right kind to fit. Bought the fat feed wire, and a 50A RV outlet too: https://www.homedepot.com/p/GE-50-Amp-Temporary-RV-Power-Outlet-U054P/100193650
I didn't bother with the outside breaker. Didn't see much need for it since I power down the RV electrical appliances before connecting or disconnecting.
I wish I would have put in the 50A to begin with. At least I can use the old wire in the wall to pull the newer (larger gauge) wire.
Robert
Merritt Island, FL
2023 Thor Quantum KW29
2006 Jeep Wrangler Unlimited TOAD
2023 Jeep Gladiator Rubicon TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
Tom_Barb
Our M/H requires 50 AMP, so that is what we installed. 1 small box on the side of the house.
js218
Have full hook ups with 50 amp service installed at 3 properties in 3 different states all installed by licensed electricians, all work as they should. If unable to do it yourself hire a professional.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
Halmfamily
I have a 50amp receptacle installed for our RV. We use our RV as a guest house when company is here and they can run whatever they need. For the little extra in money go 50amp.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
Cummins12V98
"I think I'll keep it simple and get a basic 50 amp install"
Good call!!!
No need for a outdoor disconnect. Use the 50A breaker for your disconnect.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
STBRetired
I installed the 50A connection so that I don't have to use a dogbone adapter with the 50A plug on my MH. The 50/30/20 lets any of my friends "camp" in my driveway if they come for a visit. I also use the 20A for various power tools when working outside on that side of the house. I ran the #6 wire to support the 50A, but only have a 40A breaker in the main panel as I had one laying around.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
DrewE
What I did (note: actually did) was install a 30A receptacle for my RV, and a switch inside the garage dedicated to it. There are readily-available heavy-duty light switches rated for 30A, though normal light switches are not.
Since the RV box would not be the same circuit as the house A/C, you need to run separate wires for it anyhow from the electric panel, so I don't see where you're really saving much by combining the two jobs, at least in terms of materials. It may well be some savings in labor to do both at the same time.
pianotuna
Nomad III
Nomad III
I would install a 50 amp single outlet box.
Regards, Don
philh
Real simple, how much to run and install the 50 wire and pedestal, how much to run 30a. I think you'll find, the cost to be only slightly higher. Will you ever need it, highly unlikely... but I'll bet for the cost difference... you have to make that decision.
