โAug-23-2015 08:01 AM
โAug-24-2015 01:01 PM
True, but Trailer Life was quoting a Dexter spokesman.
Teach
โAug-24-2015 12:14 PM
FlatBroke wrote:
EZ lube = nice greasy bearings AND brakes.
โAug-24-2015 11:46 AM
โAug-24-2015 09:11 AM
โAug-24-2015 08:46 AM
jmtandem wrote:
Dexter makes the axles, not Trailer Life.
โAug-23-2015 09:09 AM
In the โRV Clinicโ section of the September Trailer Life, a reader asks about his E-Z-Lube Dexter hubs. In his response, Jeff Johnson replies, โโฆthere is no manufacturer recommendation for adding grease to those hubs between regular maintenance intervals. According to a Dexter spokesman, those hubs were designed for the marine industryโฆ.The Zerk fitting allows the bearing maintenance technician, following the regular 12-month or 12,000-mile inspection and repack, to pump in enough grease to fill the entire void inside the hub with grease. This feature is, of course, not needed for RV trailers, (my emphasis)โฆ.โ Johnson and the Dexter rep are not discussing โBearing Buddies.โ The article (page 126) is clearly about E-Z Lube hubs.
According to the manufacturer, as of September 2015, they were designed for boat trailers and are not needed on RV trailers. The take-away from this is, according to the Dexter spokesman, bearings should be inspected and repacked 12-mo./12,000 mi. The E-Z Lube fitting is for a bearing packerโs one-time use if servicing a boat trailer.
Now does this jibe with the Dexter manual you got with your trailer? Or is Dexter sending a confusing message?
(Please note: This isnโt a poll asking what you do or why you do it. That topic is a dead horse, several times over.. I want us to share what our understanding of the hubโs use is based on the written evidence in hand.)
Teach
โAug-23-2015 08:57 AM
