Advise on Solar Mounts ....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Feb-24-2017 05:49 AM
Before you get all jiggy on that I'll tell you that Cat is an Electrical Engineer that works for a solar company and we've both been in solar for over 9 years. We have the knowledge and experience of building farms and even smaller off-grid set ups.
The problem is that we haven't installed any on RVs.
What brackets have you used? What did you like? What do I need to be aware of?
Our RV, Jack, likes to go fast. He's easily pulling 75 on the freeways when that's reasonable. So that's a consideration also.
We are having the roof resealed next week and while they are up there they are going to attach the panels to the roof and seal the mounts.
I have to order mounts.
What am I purchasing?
Our Motto: Love. Joy. Hope. Peace. Freedom.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-13-2017 01:46 PM
Converting things like TV doesn't make much sense, modern LED TV draws very little power. 100W inverter will do - with remote switch, or make it accessible and turn it off when not in use.
12V fridge of modest 6-7 cu.ft size your solar could handle in summer, will be pushing the limits in winter - not gonna make it on some days, so you'll dip into your battery resources "deeper", and even 6 cu.ft model will be a costly affair.
12V A/C - have some doubts. Removing that much heat from the trailer to the outside requires a lot of energy - KWH, no matter in 12V or 110V.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-13-2017 06:37 AM
Almot wrote:
Yes, I noticed that small panel on the A/C.
In summer, and without controller, it could even over-charge a small battery if there are no parasitic loads, i.e. engine battery is disconnected from everything except for this panel. OTH, if there is anything drawing power while in storage, it might not be enough to keep the level of charge where it was.
I have a trickle charge mounted under the hood. The cord for it runs into the coach. It's easy to keep that going from inside.
Ultimately Cat wants to convert much of our stuff to 12v. That will involve purchasing 12v adapters for our laptops and electronics. Then we will look at replacing the fridge and eventually the A/C as there are more and more 12v A/C units hitting the market.
If we could get these devices in place we could unplug Jack. The eventual goal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-12-2017 08:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-12-2017 04:06 PM
Almot wrote:Joel_T wrote:
A/C? Looks like what ever you tied to it ran away with parts of it. 🙂
Shrouds are often made of inferior material. Either vinyl or lower-end fiberglass (not the kind used on average FG boat). After 3-4 years in the Southern sun it becomes brittle and cracks. Black color for roof A/C wasn't a good idea either.
Yeah, that thing has taken a beating. We added a shroud to the front vent. Not sure why it wasn't there. The guy moved the one from the bathroom up there so it would be black. Personally I want to replace all that stuff up there with nice new stuff and it will all be white. I think the previous owner's black fetish went just a bit too far.
There are new A/C shrouds in black at the supply store but I'm not sure I like them. The little solar panel on the shroud now isn't doing anything. It is supposed to be charging the engine battery. It isn't.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-11-2017 09:24 PM
Difficult to see, there is a threaded 1/4" x 1" x 3" alumunium flat bar pop riveted inside the frame at all 4 mounts of each panel.
I only add the tilt bars when wintering for a month or more in AZ, and the sun arc is low in the south.
I have had "nutserts" fail/spin in previous installs, therefore the more positive threaded flatbars riveted to the frame.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-10-2017 11:49 AM
Unless you can get somehow into that 1" crack under the panel and attach/remove a regular lock-nut on the other side.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-10-2017 04:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-10-2017 04:39 AM
2015 Keystone Raptor 332TS 5th wheel toy Hauler (sold)
2004 Winnebago Vectra. 2011 Jeep Grand Cherokee toad
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-10-2017 02:51 AM
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-10-2017 12:40 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-09-2017 05:47 PM
What happened to your A/C? Looks like what ever you tied to it ran away with parts of it. 🙂
Two 6v Crown 260ah / TM-2030 monitor / SC-2030 controller / Two 160w panels / EMSHW30C surge protector / 2000w inverter / TST507 TPMS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-09-2017 04:09 PM
westend wrote:
With the shading issues here it looks like only one panel is producing any real power, except for high noon. A tiny bit of shade will kill the entire panel output. Remember these are series devices. ALL wafers need to be in the sun.
2007 Aliner high wall expedition
1997 28' Sportsman TT
1994 Flagstaff PU
Many camping boats before...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-05-2017 01:07 PM
I don't think that 3*250W is overkill. It does rain in SoCal - yes, in desert. People there tend to camp in winter at least as often as in summer, if not more. On a winter day if it rains all day you'll barely harvest enough to keep battery where it was before, with only fridge and few lights running. Though in MH you probably have a generator.
Mounting... Can't be 99% positive at this angle, but a few things look not quite right:
Not enough sealant under the bracket. It should be oozing from under the perimeter, on all sides, overlapping the bracket area by 1/4-1/2 inch.
TAD small footprint of each bracket, too.
Also, it looks like they are L-brackets, not Z-brackets. If you will ever have to remove the panel for any reason, getting those fasteners out of the frame or reinstalling them again will be a royal pain. The only instance when this type of mount is OK is when you are using rivnuts in the panel frame, so there are no locknuts on the other side and bolts can be easily removed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Mar-05-2017 11:33 AM
Searching_Ut wrote:
The mounting looks good to me. Given your roof design, it appears you'll probably have shading issues on one or more of your panels during parts of the day depending of course on where and how you're parked. To maximize your daily energy harvest you'll want to make sure your wiring and controller is set up to account for that.
Yep. The reality is that this is a bit extreme for a motorhome. It's not like we're running a bunch of stuff in there at the same time. So the shading issue, although very real, isn't that much of a concern.
We have a 40* rule. That's not outdoor temperature, that distance from the Equator. We're desert people so the sunlight is amazing and typically (although not this year) we experience 310 days of sunshine per year. Staying out of the Frozen Tundra (41* or higher) will help the kit perform very well.
Cat, my girl, is the Electrical Genius putting this together. I'm confident that she will get this running very well.
The panels were in exchange for Rife Therapy.
The charge controller was a gift from on off-grid customer.
We came into some budget issues so the inverter is on-hold currently.
The batteries will be AGM and that will require a modification to a storage box. So the final bit will take a little longer to complete unfortunately.
Thanks !!
