โJan-25-2016 02:44 PM
โJan-26-2016 06:38 PM
pnichols wrote:
Just as a side note ... rate of change of state-of-charge as you're using a battery versus it's capacity are very much related to each other.
That's why I finally got rid of our last set of RV batteries. Their state-of-charge was dropping too fast when we were camping as compared to when they were new ... which meant that their capacity was no longer what it was when they were new.
โJan-26-2016 05:38 PM
โJan-26-2016 11:03 AM
โJan-26-2016 10:42 AM
Almot wrote:Chris Bryant wrote:
All of the AGMs tested 100%, and had the spec'd resistance, after over 6 years of heavy use.
If this tester shows that battery didn't change resistance after 6 years of heavy use, I wouldn't trust it.
I wonder what Mex would have to say on these miracle devices.
โJan-26-2016 10:41 AM
woodhog wrote:
Will the Trimetric come up with similar results if I can figure out
how to program it at another level, mine is L1 at the moment.It is a 2025.
Are all three measuring the capacity left in a battery that is not new?
โJan-26-2016 10:21 AM
โJan-26-2016 09:35 AM
โJan-26-2016 08:48 AM
Chris Bryant wrote:
A while back I bought this battery tester, which measures capacity using internal battery resistance.
FWIW, seemed to work fine on the AGMs I tested it on, and a couple of regular flooded batteries. Gives capacity in percentage.
โJan-26-2016 08:25 AM
โJan-26-2016 07:07 AM
โJan-26-2016 05:15 AM
โJan-25-2016 08:25 PM
โJan-25-2016 07:09 PM
landyacht318 wrote:
Capacity test.
Divide listed amp hour rate of battery bank by 20.
A 100 AH battery can power a 5 amp load for 20 hours before voltage drops to 10.5v.
โJan-25-2016 06:20 PM
