Air Compressor
dhuse
Is there a usable air compressor (like to pump up tires} on a Forza?
7 REPLIES 7
2oldman
Ava wrote:
If you have air brakes you can add a fitting to the built in compressor system.
Or air suspension, then there may be a fitting somewhere. I googled it and it says you do. Or perhaps there's an owner's manual hidden away somewhere -assuming you own this.
Everyone is not reading your actual question.
jplante4
Every time this subject comes up, the Porter-Cable pancake compressor comes out on top.
HoD has them.
I have one. Airs up my tires to 95 psi, Fits in the basement.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
kerrlakeRoo
I've got one of these
https://www.lowes.com/pd/Kobalt-12-Volt-Car-Air-Inflator/1000092575
It runs on 120 VAC or 12 VDC, is fairly quick, not as noisey as my last one. And it has auto shut off for whatever pressure you set it for.
I have only used it for tires up to about 80 psi, label claims 120.
Ava
If you have air brakes you can add a fitting to the built in compressor system. I found a good portable 12v one online that can pump to 150 psi. Made by a co. called Trewell
Mandalay_Parr
Never had one in 14 years.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
dhuse
Sorry. A Forza is a Winnebago diesel pusher motorhome.
Dick_B
Don't know what a Forza is but we carry two compressors; one for TV and RV tires and a little one for bike tires. While you a waiting for responses you might search this Forum for `air compressor' and read on.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
