โJul-09-2014 08:53 AM
โNov-03-2014 09:02 PM
โNov-03-2014 08:27 PM
RoyB wrote:
I tolled with this concept alittle bit. I know of a couple that has done this with there smaller trailers and was amazed how well it worked.
Several on here have some things already working along this line...
My IDEA here...
Here is one install that worked great...
I know of a couple of designs using wall mounted heat registers in a couple of zones around the trailer - bath room being one...
I know of another HYDRONIC Install using tubing coils around the underbelly tanks to keep from freezing that works fine with circulating hot water.
Many of the big Diesel MOTORHOMES already use this concept with multi-heat zones...
I could setup my HOT WATER heater to do this for my OFF-ROAD POPUP for around $300 and completely do away with the propane fired furnace and very loud furnace 12VDC blower
Roy Ken
โJul-09-2014 05:02 PM
opnspaces wrote:I believe a pump is necessary for this application. Of course, it all depends on room size, ambient temp, and insulation values. Using a smallish exchanger and assuming typical RV construction, one would like the hottest temperature possible at the exchanger. That would mean a pump is necessary.
I've always found this intriguing and want to build one some day. I'm curious though if it could be made without the water pump. I seem to remember that back in the late 70's or early 80's when the water cooled motocross bikes came out that the Kawasaki KX bikes did not use a pump. I don't know what it's called, convection, thermal dynamics, whatever, but the concept was that hot water would rise to the radiator and the cold water would sink back to the motor.
I don't know how well this system worked for a high revving motocross bike, but for what we're talking it might be perfect.
โJul-09-2014 02:20 PM
โJul-09-2014 02:17 PM
โJul-09-2014 01:19 PM
โJul-09-2014 12:25 PM
โJul-09-2014 12:24 PM
beemerphile1 wrote:
This thing looks good. I think many boondockers have been waiting for this.
โJul-09-2014 11:30 AM
โJul-09-2014 11:26 AM
โJul-09-2014 11:25 AM
RoyB wrote:
My IDEA here...
โJul-09-2014 11:20 AM
โJul-09-2014 11:05 AM
โJul-09-2014 10:47 AM
