Cool Grill!!
mchero
Looks like the pellet grills/smokers are the big rage now. I posted about the new Davey Crockett WiFi pellet stove in the cooks section.
http://www.stlbbqstore.com/green-mountain-grills/green-mountain-grills-davy-crockett-wifi-pellet-gri...
Best of all it's somewhat portable & uses 12VDC for the electric supply!
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
23 REPLIES 23
mchero
Thanks for the PICS BigCityPoPo!!! Awesome!!My next grill will be the Davey Crockette!!!
I bet if you pull into an RV park and fire up your pellet smoker you will make lost of friends real quick! LOL
Robert McHenry
bigcitypopo
I have two navy wool blankets I use. They work great.
2014 RAM 2500 BigHorn CrewCab 4x2 ShortBox, 6.7L CTD
2014 Keystone Springdale 294bhssrwe - Hensley Arrow!
The best wife, 2 kids and a bunch of fun
Bigdog
On roasts with my Trager,I used alder and mesquite mostly. One thing you'll find with a pellet bbq is that when it's cold you'll need to have the thermal blanket and you do lose at lot of heat when you open it up to check your cooking and it takes time to get the heat back up. That's why you usually start it on high and then turn it down after you put your food on.
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
bigcitypopo
Cherry and oak are awesome with tritip
bigcitypopo
100w start up... 10w running after ignition... The fan control is awesome. Cycles on and off, stokes fire. Precise auger control. Temp didn't vary more than 2-3 degrees... Even at 400deg
NinerBikes
I wonder what type of wood for wood pellets would go well with a Tri Tip Roast? Red Oak?
I'm gonna need more solar panels and batteries for that. We need to know the amp draw of the motor and ignitor on 12V. Does it give a UL listing and have a plate stamped with the numbers?
Popo, you are killing us with this, Ventura is not that far for a BBQ, :C
NinerBikes
Double post.
bigcitypopo
Boom!!!
out of the box, a few screws tightened... that's it
12V stuff
The Adapter puts out 12.7 Volts steady... even at start up... no dip
The App Rocks.. Full control via wifi... 50ft and counting so far...
a quick Vid
MEXICOWANDERER
AGHHHH! I'm caught down here with mere Dorado, and halibut, mesquite smoked. You are in an excellent place to try dungeness crab smoked with good old manzanita.
This thread is driving me freakin' nuts! (stomach growling)
down_home
pellet stoves first came out they were to use corn, something farmers had a lot of.
I wonder if the pellet grills and stoves can still use corn.
bigcitypopo
Boom. Cooking now... Two chickens. The wifi is awesome!!!! And thre are some rad upgrades via firmware in the works!!!! I'll post pics in a bit
mchero
Nice reviews on pellet stoves.
BigCityPoPo, Keep us posted on your new grill
Robert McHenry
Bigdog
Trager,the only way to BBQ. We have several BBQ places that use Tragers for their cooking and they actually put out a superior product to the one real pit bbq here.
GO COUGARS
NinerBikes
MEXICOWANDERER wrote:
Few things are as rewarding as apple smoked bacon and mesquite smoked elk. Smoked salmon (actually LOX) is a classic. Yummy!
Spring run Ocean caught King salmon, properly brined and smoked over Alderwood chips. With a dash of Sage honey on the salmon to add just a little sweetness. Heaven!
The Big Chief smoker takes 8 hours at 120V.
