Another Disc Brake Question
So, i had the IS and Disc option installed on my Redwood back in June. I have 2 trips with them and am still having a TON of dust build up on the rims.. The first trip was 200 miles round trip, and I just finished a 1200 mile trio down to Florida. I check all my temps at each stop and they all seam to be in sync with each other.
These are my 3 disc options so I am no stranger, but do not recall this much dust .
All 4 wheels are evenly coated, and they look black once I arrive.
The folks at Morryde have told me that they believe it should go away soon, as long as i do not have a pad or caliper hanging. I do not believe that I do, as all my temps are about the same and I assume 1 would be higher if I did.
Should I worry?? Should I stop thinking about it??
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
10 REPLIES 10
Fulltimer50 wrote:
First thing I thought of was maybe your controller gain is too high allowing the trailer to do most of the breaking.
That was ny first look..
Changed the dash settings from medium to low.. and IBC to 6.0
Me-Her-the kids
Fulltimer50
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
Cummins12V98
Planning wrote:
I just switched out from Titan ceramic (time for new) to NAPA UP7136M semi-metallic. Not many miles on them yet but no discernible dust issue.
Yup. Good call. HD loads are NOT for Ceramic pads.
Next time around I will be looking for US Made Semi Metallic pads. NAPA unfortunately went to Mexico with their top of the line pads.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Planning
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
Not whining, just asking if the amount of dust was normal.. But thanks for taking my question and turning it into a whine in your eyes
Me-Her-the kids
SidecarFlip
Cummins12V98 wrote:
They are NOT Ceramic. They call them Ceramic like. read the details. True ceramic is a big mistake for HD applications.
Proper pads are SemiMetallic of HIGH quality as in not the CHINESE POS PADS that they install.
Kevin at Kodiak told me that they did not sell any QUALITY pads because no one wanted to pay the price and to go to NAPA or the like and buy HD SemiMetallic pads.
Whatever. been running EBC CERAMIC pads for a while now and drilled and slotted rotors as well.
Don't know who Kevin is and don't much care. Opinions are like but holes, everyone has one, some stink some don't.
Once I switched to CERAMIC pads, my brake dust issue vanished and I have had ZERO issues with stopping, pad squeal or rotor wear.
Just this afternoon put a set on my wife's Suburban.
I don't concern myself with cost, I get them at cost.
Don't much care if you drill a hole in your floor and jam a stick into the pavement to stop. All I said was, to eliminate brake dust. switch to CERAMIC pads.. Nothing more.
Do what you want to but don't whine about brake dust.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
edbehnke
cummins said it all. the dust is just your pads...if you don't like the dust on the wheels just change them out.
eddie and sandie
3402 Montana 2013
Ford F350 2015
Cummins12V98
SidecarFlip wrote:
Not going away until you switch to ceramic pads. I quit running composite pads on all my vehicles a while ago. Ceramic's don't make the amount of dust composites do. being an EBC dealer, I run EBC pads but any ceramic pad will do.
Gary at Morryde told me they used ceramic
Me-Her-the kids
SidecarFlip
