โNov-13-2018 02:38 AM
โNov-15-2018 04:31 AM
rtate wrote:
The converter is supossed to hit the battery in boost mode every 21 hours to desulphur the plates. I dont know if it is doing that.
โNov-15-2018 03:29 AM
โNov-14-2018 07:11 AM
Bobbo wrote:
This thread, the OP is just wondering why he is not seeing the 14.4v at the battery when he STARTS charging.
โNov-14-2018 07:04 AM
rtate wrote:11v is a bit over discharged unless that is under a moderately heavy load. Otherwise you are looking at closer to 4 hours.
Can I expect my t105s to go from 11v to 90% charge in a couple of hours?
โNov-14-2018 06:54 AM
rtate wrote:No need to disconnect anything. Just plug in and monitor the battery voltage. When you see voltage rise above 14 you know all is well. Besides if the converter has no battery to charge it may just produce 13.6 volts.
So after trying to understand what everyone has told me this is what I am planing to do . Since I am not able to get easy access to my converter, I will disconect the wires from the converter to the batterie and take a reading of the voltage coming from the converter If my converter is doing its job, I should see a voltage of 14.4v coming from the converter. If I do get 14.4v I will then upgrade the wire from the converter to the batteries. If I do that I will see the batteries reach 14.4 v when charging.
If I dont see the converter putting out 14.4v when disconected from the batteries, then I have a converter problem.
Does my take on this make sense?
โNov-14-2018 06:49 AM
BFL13 wrote:Plenty of posts where IOTA puts rated amps on the battery all the way up to full 14.6/14.8 volts (at the converter). Yes once the voltage limit is met the amps taper off due to the battery chemistry. Yes as IOTA drops to 14.2 volts for absorption there again amps will be tapering due to battery chemistry.time2roll wrote:
To my knowledge based upon reading many posts... only the IOTA will produce full amp rating and full voltage rating at the same time.
Where in the Iota charging profile does it do that where you can see it? The converter is set to a voltage, but you don't see it unless it is disconnected or else when the battery is full and no other loads. Iota is set to 14.8, gets the battery to 14.6, waits 15 minutes (when the battery voltage rises to X) and then drops to 14.2V
Most (all?) converter specs (ratings) are at 13.6v, but they are supposed to be able to do full current-limited amps at that or at their boost settings.
PowerMax and other converter/chargers hold constant full amps at their boost settings too, but PDs seem not to according to most posters on here. A few have made their PDs come close to doing it by using very fat short wire to the battery.
โNov-14-2018 06:42 AM
BFL13 wrote:
T-105s or any other battery should not be down to 11 volts! 50% is 12.1 volts.
A pair at 225 AH at 50% with a 45amp charger doing constant 45 will take about 85 minutes to get the batts to 75% , another 20 min to 80%, and another hour from 80-90. So total 50-90 will take about 3.4 hours. the 80-90 for an hour might not be worth the gen time, which is why many do 50-80s instead.
โNov-14-2018 06:14 AM
Tom_M wrote:
There's no difference whether using generator or show power. Your converter will start in boost mode at 14.4 volts
โNov-14-2018 04:47 AM
time2roll wrote:
Measured at the converter yes voltage should steadily climb to 14.4 volts. Under initial full output the PD9245 could be closer to 13.4 or even less. Voltage tends to sag a bit on the PD. You will never see full amp rating at 14.4 volts. Battery voltage on the terminals will be somewhat lower due to the voltage drop in the wire connection. As the amps taper into the 3rd and 4th hour the battery terminal voltage should be rising steadily to 14.4 volts.
โNov-14-2018 04:31 AM
โNov-14-2018 04:23 AM
โNov-14-2018 02:50 AM
โNov-14-2018 02:23 AM
โNov-14-2018 02:11 AM
