โApr-15-2018 10:41 AM
โApr-16-2018 08:54 AM
BFL13 wrote:
Thanks to Doug for being on the Forum and still helping guys out. (He has said he gets fed up sometimes with repeating the same things, so extra credit for sticking around!)
Doug has set me straight a few times, and helped me with some trouble-shooting on my RVs here too, so I just wanted to throw in that I hope he keeps helping us.
โApr-16-2018 08:53 AM
dougrainer wrote:
Good Video. Bad news. Atwood will probably not be responsible for this problem as it is a bad install by the OEM. Yes, the design and run off of the slide cover has caused your water intrusion. The removable door needs to be installed better with a better gasket. DO NOT use silicone to seal the removable door. Your real problem is the vertical mount. It is OK to install vertical, but you must take special care tom prevent water intrusion. Your interior where all the water is, is causing the circuit board to not function. If you dried out the area and the circuit board the furnace would probably run correctly. The furnace will NOT run if you leave the chrome exhaust pipe OFF. You can just insert it into the exhaust metal pipe to run the furnace once it is dried. Without the metal exhaust pipe installed the intake impellor will just draw exhaust gas back into the chamber and snuff out the flame. If it was my unit or my customers unit, I would make and install a drip cap on top the furnace mount to make sure the water could not flow down the side of the furnace from the slide cover. Doug
โApr-15-2018 05:47 PM
โApr-15-2018 05:06 PM
โApr-15-2018 02:46 PM
โApr-15-2018 11:01 AM
dougrainer wrote:
In 38 years of being a RV Tech, I have never heard such a noise from a furnace. The unit will have to be pulled to check it out. Water cannot get to the burner unless you shot water directly in with a water hose and even then it would take a minute or so for the water to get to the burner assbly. Rain water cannot get that far. Atwood has a 2 year warranty. Is yours still under the 2 years? Doug
โApr-15-2018 10:57 AM
โApr-15-2018 10:51 AM
Artum Snowbird wrote:
I would think that you have a stuck "thing" in the furnace squirrel cage motor. It's stopping because there isn't enough flow to trigger the flow switch.
But, that is my opinion.
โApr-15-2018 10:46 AM
