โMar-04-2022 11:25 AM
โMar-09-2022 05:57 AM
StirCrazy wrote:dougrainer wrote:StirCrazy wrote:dougrainer wrote:StirCrazy wrote:
probably a rech, has anyone played with the anticipation setting in the thermostate. when I got my camper it was short cycling like crazy then I looked at that and set it back yp to factory andit works good. trying to figure out what I can replace it with now that I don't have to buy from a rv shop that maybe will be a little better at the heat swing.
Steve
If you have an electronic Tstat, there is no anticipator setting. Doug
where did you see it mentioned that he had an electronic Tstat? and if it is a digital, then you are adjusting the Cycle rate... same results different name.
Steve
He stated a Dometic Model number instead of Atwood(Dometic purchased Atwood). That tells me he has a less than 10 year furnace and almost ALL RV's use a electronic wall tstat now. Only inexpensive cheap RV's use the old style bi metal wall furnace tstat. HOW do you adjust the cycle rate on an electronic wall tstat? What do you mean by CYCLE RATE? The CCC2 Dometic has a TEMP DIFFERENTIAL setting of plus or minus 2. Doug
real cheep ones probably have a set cycle rate, and knowing the rv industry :B most likly its getting into the programable ones to get access to the cycle rate.
Im trying to find a good 12V two wire one for my old hydroflam in my camper. some one butchered the insides of the old one playing with the antisapator setting and I have it working reasonable again but I want to upgrade it. anything I find that is good they want a fortune for up here.
โMar-09-2022 05:19 AM
Steve
Steve
โMar-08-2022 06:34 AM
Steve
Steve
โMar-07-2022 04:29 PM
Steve
โMar-07-2022 06:24 AM
Steve
โMar-06-2022 04:11 PM
โMar-05-2022 07:49 AM
Gdetrailer wrote:dougrainer wrote:
"Regulator malfunction can result in higher propane pressure to the furnace which affects flame size.. Check the burners on your stove, flame should not be excessively high and should be all blue".
This will not work. The Stoves/Ovens have their own regulator set at 10 inches water column. So if the LP regulator is too high this regulator will fix that for the Oven/Stove. Doug
RV furnace gas valve also has "it's own" regulator same as a home gas furnace and even home gas stove and oven, but those also can be affected by the incoming gas pressure if it is too high or too low..
โMar-05-2022 06:15 AM
โMar-05-2022 05:45 AM
โMar-04-2022 07:36 PM
Gdetrailer wrote:OK and mine malfunctioned for almost ten years before I dug in and fixed it.time2roll wrote:
My OEM ducting was inadequate. I added 2x 4" additional ducts and the furnace works so much better with tons more heat and the burner stays on the entire cycle.
I believe OP has had this RV for a while and this IS a recently new "symptom".. If I am correct, that would make the assumption of not enough ducting not much of an issue unless a new blockage has been introduced (like a blanket covering a register?)..
โMar-04-2022 07:32 PM
โMar-04-2022 07:29 PM
โMar-04-2022 06:45 PM
โMar-04-2022 05:21 PM
