Batteries will not charge on shore power.
Breed1229
Ok, this group has been a great help with previous issues, so I’m hoping you all can help me again.
The issue is. When I’m pluggyup to shore power, my batteries will not charge. They used too. I checked my power converter and it is putting out 13.5 v to the distribution panel. It just isn’t getting to the batteries.
I made sure to check the reset button on the left of the board and checked all the fuses. I must be missing something. Relay? Hidden fuse?
1999 seabreeze it has the Custom RV products 12v distribution board.
I’m sure I’m overlooking something silly.
Thanks in advance.
12 REPLIES 12
fischer
I had 2005 southwind with BCC I replaced a charging relay inside.
Go on line and search
Battery control center trouble shooting guide
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
Breed1229
Found the issue. Bad 50 amp breaker in the Power Distrabution Panel.
Thank you for all the reply’s. Happy camping everyone.
ppine
How old are your batteries?
ppine
delete
Sam_Spade
Breed1229 wrote:
My converter is putting out 13.5v measured at the converter and the power distribution panel. It’s just not getting to the batteries.
Battery disconnect switch ??
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
MFL
Nomad II
Nomad II
What voltage are your batteries showing? Could be the circuit breaker, but the disconnect should be obvious if applicable. Even with the charger working, if only putting out 13.5, it will take a while to charge batteries discharged to 12 volts, or less.
Jerry
MrWizard
Moderator
Moderator
Battery disconnect switch?
Do NOT use battery disconnect when on shore or generator
I can explain it to you.
1997 F53 Bounder 36s
SoundGuy
There is, or should be, a resettable circuit breaker in the positive cable connected to the battery's positive terminal. Have you checked it?
2012 Silverado 1500 Crew Cab
azrving
As Vee said, use the volt meter at the battery. Depending on how it's wired the problem could as simple as a bad connection at the battery. Battery connections corrode. Is it a wet cell battery? Have you checked the electrolyte level? Is it covering the plates?
Breed1229
azrving
Veebyes
From my understanding a converter provides power to the DC system & it is a charger to the battery bank.
Put the volt meter across the battery bank. If you are not getting 14V there you likely have a charger problem. If you are getting a better than 12V reading on the battery bank but no charging then chances are the battery bank is shot.
2007 Alpenlite 34RLR
