Batteries
mclainfarm
I have 4 6 volt Duracell batteries and trying to figure out the amp hour rating. The specs are
20 amp hour rate 215
5 amp hour rate 157
6 amp hour rate 156
Minutes at 25 amps 395
Minutes at 75 amps 105
Most batteries I read about state they are 100 amp hour batteries. What are mine? Iโ€™m trying to put together a solar system and need to know the size of my battery bank. Thanks for any help
Dwayne
1999 FORD F350 DRW 7.3 DIESEL 240000 MILES
2014 Palomino truck camper
16 REPLIES 16
theoldwizard1
The most commonly used rating is the 20 amp hour rating
"The amount of amp-hours (AH) a battery can deliver when discharged at a constant rate at 80ยฐF (27ยฐC) and maintain a voltage above 1.75 V/cell."
1.75 V/cell is past the typical amount you would discharge a battery to and, if done repeatedly, will shorten the life of the battery. For maximum life, do not discharge past 80% "state of charge" (SOC) which is 2.08V/cell. (12.48V for a 12V battery bank.)
Minutes at 25 amps (also referred to as Reserve Capacity) is another good reference, but not all manufactures publish this.
Yours are 215 amp-hours, typical for most 6V golf cart batteries. If they are wired 2 in series and then 2 in parallel, you have 430 amp hour @ 12V.
wolfe10
ON EDIT: Thanks to all who posted below who corrected my "BAD MATH". Concept correct, math not so much. Rather than leave questions, I will edit to supply, as others have done the correct answer: 430 AH @ 12 VDC.
The 20 hour rate is the most common rating.
So, each of your batteries is 215 AH @ 6 VDC. So each pair wired in SERIES is 215 AH @ 12 VDC.
Both pairs together (your battery bank) is 430 AH @ 12 VDC.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
