โDec-14-2013 06:34 AM
โDec-17-2013 04:55 PM
โDec-17-2013 04:31 PM
โDec-17-2013 09:19 AM
โDec-17-2013 08:32 AM
westend wrote::B
Doh: Mena and I are thinking alike and at the same time:D
โDec-16-2013 08:30 PM
โDec-16-2013 08:27 PM
hpcbmw wrote:Unless it has a 6V setting, you'll need those two batteries in series when connected to that charger.
Anyone know if I can use the "conditioning" on a 6 v battery, or on the two 6v batteries connected as a big 12v battery?
Thanks for all the info so far!
โDec-16-2013 08:11 PM
โDec-15-2013 07:47 PM
โDec-15-2013 07:29 PM
hpcbmw wrote:The Multi unit from Ctek has a maximum amp output of 4.3A. You will be waiting a long time, if ever, of bringing your batteries back to a full charge.
Does anyone know if a C-tek charger will desulfate and charge an almost dead RV or car battery? I'm under the impressions that you want alot of charge at first, then taper off to a low charge as it tops off. The C-teks look pretty small - can the put out that much charge? Maybe size doesn't matter....
Right now I'm tending towards the Stanley 40amp BC4009 at Lowes for $100.00 - it's close by and I've got a $10.00 credit there.
Thanks
โDec-15-2013 05:57 PM
โDec-15-2013 05:32 AM
โDec-15-2013 05:06 AM
โDec-15-2013 05:02 AM
โDec-15-2013 04:52 AM
