โJul-10-2017 11:36 AM
โJul-12-2017 06:47 AM
โJul-12-2017 05:23 AM
โJul-12-2017 03:32 AM
โJul-11-2017 06:38 PM
MrWizard wrote:
Are you sure the 20 amp fuse green wire circuit is not the Jack
I would expect a black wire going to a 40 amp metal auto reset breaker mounted just under the trailer, near the the 'A' frame
โJul-11-2017 05:34 AM
Theb2b wrote:
PD4000 Series Power Control Center, this what you are looking for model of the converter?
As for the wire 8 gauge from the trailer into a wirenut(think that is what it's called?) then 10 gauge to the battery and another 10 gauge to the jack. The fuse is between the wirenut and the battery.
โJul-10-2017 10:49 PM
โJul-10-2017 06:38 PM
โJul-10-2017 05:29 PM
Bud
USAF Retired
Pace Arrow
โJul-10-2017 04:47 PM
enblethen wrote:
Polarity sounds correct.
Do you get power from the truck so lights in trailer work? The answer should be yes.
Do you have a volt meter?
โJul-10-2017 04:19 PM
Bud
USAF Retired
Pace Arrow
โJul-10-2017 04:18 PM
โJul-10-2017 03:58 PM
Theb2b wrote:
Ok, the white lead is negative, it runs to the frame of the TT while the green lead is the positive lead and has the inline fuse plus a lead running to the jack.
Now I did take the battery out for the winter, but I took a picture of the connection so when I put it back in I got the leads connected correctly.
โJul-10-2017 03:45 PM
enblethen wrote:
Sounds a little small. Check the size of the wire from the battery to the 12 volt distribution panel. Check the size of the converter output. I would guess it should be at least a 30.
I think you have another issue. The truck isn't feeding much more then 20 at the connector.
I would check the polarity of your battery. It sounds like it could be reversed.
โJul-10-2017 02:25 PM
Theb2b wrote:
Any thoughts or need more information please let me know.
