Battery Disconnect Switch
Iceman31
Ok stupid question. Our new trailer has a battery disconnect switch. This morning we had a power outage. My battery is dead. I had the switch in the on position which I thought was correct. Should it actually be off in order to allow the battery to charge? I have never had one of these switches in any other unit I have owned.
2019 RAM 1500 Classic Express Night Edition
2018 Venture RV Sporttrek 343VIK
2017 Hyundai Tuscon SE AWD
2016 Hyundai Sonata Limited
2014 Chevrolet Camaro LS1
2004 Ford Mustang GT Convertible
2011 Crestliner Superhawk c/w 115HP Mercury
2012 Honda CBR250
14 REPLIES 14
fj12ryder
I would say you did it correctly and have another problem. You need to check the voltage coming out of your inverter, or if there even is voltage, to the battery when you're plugged into shore power.
Howard and Peggy
"Don't Panic"
Iceman31
Yes RV has been plugged into shore power since I took possession in June. The reason I say on or off is because that is what it says on the red knob. You turn it to green which states on or red which states off.
2012 Honda CBR250
beemerphile1
First, prior to power outage, was the RV plugged into shore power?
Second, a disconnect may need to be open to charge and maybe not. In my trailer the switch disconnects loads but not the battery thus it can charge in either position.
Third, all confusion disappears when the switch is referred to as open or closed rather than off and on. Technically a switch is not off/on it is open/closed.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
John_Wayne
If you don't have a good 3 stage converter/charger and the trailer is hooked up 24/7 it could be the converter has boiled the water out of the battery and the battery is dead. How often do you check the battery water level???
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Iceman31
Trailer is brand new - delivered in June - have a seasonal site and have always been hooked up to power. Power outage this morning and had no 12 volt at all. Will have to check into it when I am done work.
2012 Honda CBR250
MrWizard
Moderator
Moderator
Battery has to be connected to the trailer
For it to stay charged
For it to power the 12v system when shore power and converter shut down
Disconnect the battery only when the trailer is in storage
Or you are working on the wiring
You may need a new battery, it might not regain its health
Depending on how long it has been sitting there dead
I can explain it to you.
1997 F53 Bounder 36s
maddog348
2oldman ~~ Thnx ~~ Double negatives always give me a headache.
2oldman
Easier to understand if you think 'battery connect switch.'
fj12ryder
Depending on the "battery disconnect" switch, it may not shut off all power to the trailer. So even if it is "Off" you can still be drawing power from the battery. Install your own battery disconnect switch and then you'll be sure you won't find your battery drained again.
Howard and Peggy
"Don't Panic"
azdryheat
Battery disconnect means just that, disconnected. It won't charge or discharge when turned off unless there is wiring that bypasses the disconnect switch.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
BFL13
On shore power, the switch should be "closed", which means the converter can charge the battery. If the switch is "open", the battery cannot run the 12v things when the converter loses its 120v input.
The battery being "dead" needs clarification. Low voltage at the battery posts using your digital multimeter? Or just no 12v in the rig now there is no power to the converter and the disconnect is open?
There is also a battery fuse or DC breaker near the battery on the pos side that could have blown (to open) that would have the same effect inside the rig as if the disconnect were open.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
pianotuna
Nomad III
Nomad III
iceman31,
The switch needs to be on for charging to happen.
Regards, Don
BB_TX
If I remember correctly, you can pull the handle out of the switch when the battery is disconnected but not when the battery is connected.
Optimistic_Para
Just off the top of my head, either they've wired the converter output directly to the battery, in which case it shouldn't matter which way the switch is set, or they've wired it through the switch, in which case it would need to be ON in order for the battery to be charged.
Sounds to me like you have a problem other than the switch.
