Battery experts - golf cart
2oldman
The GF's 36v golf cart needs batteries. I donated 6-12v 80ah AGMs, but the local cart guy is saying they won't charge properly because the charger expects "a certain amount of lead". That sounds ridiculous, but, there's a spec written on the charger saying it's designed for "18 cells" meaning, 6-6v batteries. I'm claiming that chargers recognize voltage alone, and the number of cells or amount of lead makes no difference.
I'm awaiting a response from the Lester charger people on this. What say you battery gurus?
19 REPLIES 19
azrving
2oldman wrote:
rjxj wrote:
How old is your Lester? Model number?
Model 9611
That's an older one with a manual timer. My 48 is newer and isn't even adjustable. Cheapest thing is to show her how to connect a 12 volt charger. But then you dont want it to be to high a voltage either.
2oldman
Model 9611
MEXICOWANDERER
one on each pair
Do not allow the chassis (metal cover) of one charger to touch another.
pianotuna
Nomad III
Nomad III
Hi,
The chargers can be connected in series to charge the entire bank.
BFL13 wrote:
You can recharge a 36v set with a 12v charger by doing 12v worth at a time. Eg if it is 6 sixes just do two at a time. Or you could speed things up by having three 12v chargers, one on each pair.
Regards, Don
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
newman_fulltime
2oldman wrote:
Ductape wrote:
Cheaper to buy a proper charger if it comes down to that rather than six batteries.AGM would be wonderful for a cart.
I thought so too, but gf didn't believe me after the golf cart guy convinced her I was wrong. So she bought another crappy cart from him - exactly what he wanted her to do. Good thing we don't live under the same roof.
You mean you couldnt find any old links to send her wow!!:B
2oldman
Ductape
49 States, 6 Provinces, 2 Territories...
azrving
2oldman wrote:
Guessing I'd say 20 years, or more. I can get the model number tomorrow.
Mine is an X series and some do have internal jumpers to select battery type. Some newer chargers have dip switch
2oldman
azrving
How much could he fix you up for? LOL He knows you are loaded. Many industrial or cart chargers need to see a MINIMUM voltage to be able to turn on but dont care what they are pumping the juice to. If the charger was set up to charge wet cells it may be too high of a finish voltage for agm. Depends on what the manufacturer of your agm say. Plug it in and monitor the voltage.
I have a 48 v Lester industrial charger on four 12 v series dual purpose Samuals batteries. They hit 61 volts every charge. ages: 2008, 2009, 2015, 2016.
I wouldn't be surprised to see it hit 45 v.
ScottG
He's full of it.
Lwiddis
Find another local cart guy.
