Battery powered portable fuel transfer pump
MrWizard
Moderator
Moderator
Portable Pump
I PURCHASED this last Saturday
And due to the excessive heat
And have been using it multiple times a day to fuel my pair of champion generators from gas cans
To keep the A/C going
I really like this thing and recommend it
Hard to beat for the $10 price
I have no idea about long term reliability
But in 5 days of use, I may have used it more than some people will, in a whole camping season
No more pouring gas, no more spilling gas,
Much easier and neater then holding and pouring heavy gas cans,
I am going to get some polyvinyl clear hose and extend the output hose 2 or 3 feet
I can explain it to you.
1997 F53 Bounder 36s
17 REPLIES 17
Bumpyroad
RobWNY wrote:
Bumpyroad wrote:
theoldwizard1 wrote:
RobWNY wrote:
I used to have one of those when I had a kerosene heater years ago. If I remember correctly, it worked great for a while and then bit the dust. But you're right. At the $10 price point, it pays for itself in a few uses. I recently bought one of those shaker siphons. I've only used it once but I was able to fill my garden tractor very easily.
I like mine but don't use it too often.
The biggest problem with them is that the hose comes PRE-KINKED ! There are a few places that sell them without a hose (eBay) so you can buy what you want at your local hardware ware store.
I bought two 5' sections and a nylon splice. If the one is not long enough then add the splice and another 5', no clamps necessary !
Remember that with a siphon, the tank you are taking fuel FROM, needs to be higher the the tank you are sending the fuel TO ! When putting fuel in the car or boat, I place my 5 gallon fuel jug on a tall step stool or step ladder.
are you talking about the same thing as the rest of us?
hose??????
bumpy
I believe he's referring to the Shaker Siphon I mentioned getting. He is correct. The hose does come Pre-Kinked.
but if you use one of those, you don't get the excitement of split second timing to get the siphon hose out of your mouth just before you get a mouth full of gasoline. ๐Ÿ™‚
bumpy
RobWNY
hose??????
bumpy
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Bumpyroad
hose??????
bumpy
theoldwizard1
valhalla360 wrote:
Have an almost identical syphon except it's a large squeeze bulb instead of a battery operated pump.
Probably 15yr old. I prefer manual because if it's stuffed in a compartment for months, I don't have to worry about if the batteries are dead.
Valid point !
TRDP14 Siphon Manual Liquid Transfer
MEXICOWANDERER
Ok for distillates like kerosene but not for gasoline. Been there done that. Not so small fire at campsite. Needs to be made of NYLON not polypropylene
SpeakEasy
Buyer beware.
I threw mine out this year after wrestling with it for four or five years. When it worked, it was great. But about 75% of the time it didn't work. When it didn't work it was due to corrosion in the impeller shaft. Very difficult to lubricate. If I had a new one I would spray the impeller and shaft with spray silicone every couple of months. That might prevent the corrosion. Once the corrosion is in there it is a losing battle.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
theoldwizard1
jdc1
So? No more sucking gas through a 3/8" hose? But.......
Bumpyroad
used one for years. great for filling up riding mower, transferring gas from large container to smaller one, etc. originally got them for kEROSUN HEATERS. daughter uses one for fish/turtle tank.paid closer to $17 however. great price 9.99
also have squeeze bulb model which is a pain but a backup in case batteries die.
bumpy
valhalla360
Nomad III
Nomad III
https://www.amazon.com/TRDP14-Siphon-Manual-Liquid-Transfer/dp/B00APU2YLI/ref=sr_1_4_sspa?dchild=1&keywords=fuel+siphon&qid=1597402400&sr=8-4-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyODBBQTAwUDJTQktCJmVuY3J5cHRlZElkPUEwNjQ0MDAyMU9JVU05WjlVQU9ETCZlbmNyeXB0ZWRBZElkPUEwOTk3MTAzMlBLVzgxU1lMTTQ4VyZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
RJsfishin
I have use that pump for 3 years, stil working perfectly on the original batteries. Buy a neoprene cork for the outlet.and a rubber chair leg cup for the inlet to keep the bugs out during storage. They can be had for 6 bucks when the price is right on ebay.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
pnichols
MrWizard wrote:
Portable Pump
Thanks a lot for bringing that pump to my attention!
I just ordered the newest upgraded version from Amazon. I'm tired of getting gasoline on stuff every time I deal with transferring it from cans into machines.
2005 E450 Itasca 24V Class C
Bobbo
I've had one of those for years. Don't even remember how many years. Works great. Still using the original batteries.
Bobbo and Lin
TurnThePage
It's been on my list for a couple years now. I just haven't bit yet. Maybe I will now. Thanks!
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
