โMar-29-2016 07:17 AM
โApr-01-2016 10:44 AM
โApr-01-2016 08:44 AM
โApr-01-2016 06:43 AM
Daddy Bear wrote:
So, I think the batteries were discharged when we brought it home.
โMar-31-2016 10:50 AM
Daddy Bear wrote:
I unplugged from shore power yesterday and no alarms this am. So, I think the batteries were discharged when we brought it home.
It has a WF9875 (75amp) converter. Does anyone have experience with this particular model...good/bad??
โMar-31-2016 08:19 AM
โMar-31-2016 12:04 AM
MEXICOWANDERER wrote:Check your PM
Amperage is affected slightly by temperature of the battery. In a 30F - 60F day temp swing amperage will not remain constant merely predictable.
โMar-30-2016 10:14 AM
Beemerphile1 wrote:
Maybe you left the dealer with batteries that were already discharged.
The CO detector did not drain the battery overnight. Did you accidentally pull the breakaway pin?
Not all converters are created equal. That is why you need to research what you have.
Does your tow vehicle charge the trailer batteries as you drive?
โMar-30-2016 10:04 AM
Bobbo wrote:
While my original statement is, to you, not true because you can attach to the wrong terminals, your statement is NEVER true.
โMar-30-2016 09:57 AM
โMar-30-2016 09:12 AM
Daddy Bear wrote:
We brought the new TH home last weekend. supposedly equipped with two new RV batteries. When I parked it in our yard and disconnected it from the tk it was late and we went to bed. The next am I went out to find the CO alarm was going off and would not reset. After looking up the flashing/beeping code it said the alarm was due to LOW Voltage. I hooked up shore power and the alarm silenced itself. The TH has been attached to shore power since. The TH does have a battery disconnect switch, but it was in the ON position.
Why would two brand new RV batteries not have enough voltage to run a CO detector? All of our other fifth wheel and trailers have had converters that was suppose to keep the batteries at full charge, but I have found over the years that that's not always the case. So I want to take better care from the start with these two new batteries.
โMar-30-2016 08:47 AM
โMar-30-2016 08:36 AM
โMar-30-2016 08:17 AM
โMar-30-2016 07:35 AM
Sam Spade wrote:Bobbo wrote:
Only, you hook them to the terminals that are NOT wired together.
My 2007 Winnebago came with a cheap Magnatek 7345 single stage converter that always put out about 13.5 volts. It was a battery killer. After about 3 years, I junked it and bought a good 3 stage converter, a PD4655V.
You added information. The original statement by itself is NOT true because you can attach to the wrong terminals.
What brand is the 4655 ? And was it "plug and play" or was some modification necessary to get a good fit ??
Sam Spade wrote:
The advice of connect one lead to one battery and the other lead to the other battery only works in a parallel arrangement.
Daddy Bear wrote:
Here's another tidbit of info. I checked the voltage last evening once with the shore power connected and got 14 volts and once w/O shore power connected and they bounced b/t 13 & 14 volts.
