Best lube for 3" waste fitting
RV_daytrader
My dump valves are getting hard to operate (29 years old!) and so I'm replacing them and changing the piping so they will be higher off the ground.
Anyway, the tank looks to be fiberglass? (see pic) and the abs fitting that goes in it has an o-ring and a clamp to hold it together. I am wondering what to coat the fitting with to make it slide in easier and help it to seal also.
YODA...our lil Toyota!
1989 Toyota Seabreeze
4 REPLIES 4
RV_daytrader
Thanks guys....looks like I'll use plumbers silicon grease....one regular plumbers grease Home Depot sells says NOT for o-rings.
ScottG
donn0128 wrote:
Plumbers grease. Available at any place that sells plumbing supplies.
X2!
donn0128
phil-t
Go to the auto parts place and pick up a tube of silcone grease.
2014 Allegro 36LA
