Best screws to attach WH to foam board?
wopachop
Trying to seal up exterior gaps before winter. Started with the water heater that was pulling off the wall. I tried to tighten it months ago. But noticed all the screws on the right side were stripped out. Every single one. They even doubled them up in spots. I figured its because most techs are right handed, so with the drill in their left hand maybe they were trigger happy and stripped every screw out. The screws on the left side where all snug and happy.
Took it apart yesterday and found they used wood screws into the foam insulation. No biggie i will head to home depot later. Can you please recommened the proper screws for foam board?
Thanks again Forest River. You constantly impress me with your workmanship. This is a 13 FR Stealth.
10 REPLIES 10
profdant139
wopachop said, "Yes yes the foam screw thing was my attempt at comedy." Well, you got me good! Well done.
And yes, I agree that a backer board has to be the way to go. If possible use hardwood (oak?) for greater strength.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Old-Biscuit
Good Job Forest River......
Cut out opening is 'suppose to be' FRAMED with wood both sides and top
WH is then anchored with wood screws...
time2roll
I like drywall screws for these marginal applications.
dougrainer
If you have room, PUSH the water heater further in the compartment. If no room pull the Water Heater. Then glue 2X2 wood studs up the sides and across the top on the inside to that foam board. Then once the glue dries, pull the water heater back to the correct install in the hole. Install screws to hit the new 2x2 backers and make sure you install 2 screws thru the BOTOOM if not already installed. Then seal the corner gaps with normal expanding spray foam and install the outer trim ring with its screws. The water heater normally just has the 2 screws thru the bottom into the floor, but it is best to install screws on the sides also. There is no real force that will cause the WH to attempt to slide outward as long as the 2 floor screws are installed. USUALLY, the OEM's have a aluminum or small wood studs that frame the hole cut out for the Water Heater inside the foam wall before it is laminated. I have even seen where they install aluminum angle from the inside, but the wall is usually thicker to do that. Doug
riven1950
Is there a high temperature spray foam that would work? That stuff is pretty sticky. I don't understand what exactly you are doing but just a thought.
wopachop
Yes yes the foam screw thing was my attempt at comedy. On the left side they use metal bracing, with self tapping metal screws. Is that common practice to only brace 1 side of the WH?
midnightsadie
x2 you need a back plate to screw to.
Darryl_Rita
Foam screws. In all seriousness, in a situation like that, I'd be adding a backer strip of wood to the inside and use longer screws. The original screws were intended to catch the fiberglass exterior surface, but it sounds like that's too far gone.
***UPDATE 2006 3500 SRW MegaCab pulling a 2007 fleetwood 5'er
profdant139
That is going to be tricky -- the screws are running into the narrow side of the foam board, if I am viewing the photo correctly. So there is not a lot of "meat" for the screws to grip. And you can't use screws that are much fatter -- they will split the foam board.
Is it possible to remove the heater completely? (A big hassle, I am sure.) And then fill the screw holes with something like epoxy, so that the screws will have something to bite into.
You will want to drill pilot holes, of course. Which will be hard because the opening of the water heater is not wide enough to accommodate both the drill motor and the drill bit. So you might need a right angle drill attachment.
I would recommend long stainless steel decking screws -- they will probably reach undamaged foam in order to grip better.
Good luck!
About our trailer
Fisherman
I really don't think there's much stability for screws of any type to grab in any type of foam board. I can get at the backside of my WD from inside under the dinette seats. See if you can get access from inside and use either 10/24 (3/16th) stainless nuts and bolts long enoughto hold it together.
