โApr-05-2014 05:52 PM
โApr-07-2014 09:36 PM
BFL13 wrote:I already have the switch from my old rig. ๐ And the Blue Sea switch cost me $27 but its rated for 300A fits 4/0 wire. It was my main battery disconnect on my old 5er. Re-reading the spec it says it's only good for 48V. I thought it was 600V. Guess I can't recommend that. Thanks BFL. LOL!
Hope the Blue Sea doesn't cost more than the switches I use ๐
โApr-07-2014 08:43 PM
โApr-07-2014 07:15 PM
โApr-07-2014 05:59 PM
westend wrote:nvreloader wrote:
Thanks Guys,
Since no fuses are needed,
What kind/type of electrical disconnects would you use on the panels or wiring so you could work on the wiring or system, if needed and not let the magical Blue smoke out or go for a ride on the electrical freight train?
Tia,
Don
Bussman Hi amp circuit breaker
They also make them in lesser amperage if you wish it to afford circuit protection at a lower amp rating.
I use Mid range 25 amp model
โApr-07-2014 04:42 PM
mena661 wrote:
I'm just going to use a Blue Sea switch on mine.
โApr-07-2014 04:20 PM
โApr-07-2014 03:18 PM
โApr-07-2014 10:31 AM
nvreloader wrote:
Thanks Guys,
Tia,
Don
โApr-07-2014 10:00 AM
โApr-06-2014 06:06 PM
โApr-06-2014 05:41 PM
smkettner wrote:X2
I agree, NO fuses needed on the panel side. Service disconnect maybe.
The current is self limiting. You can short the panels and no harm done.
More than two parallel technically needs a fuse.
โApr-06-2014 05:23 PM
โApr-06-2014 05:00 PM
nvreloader wrote:Let's see if I get yelled at for this answer: No, you don't need fuses on the panel wiring.
I know,I need some fuses on the panel wiring, Where should I put the 15a fuses/holders?
โApr-06-2014 04:49 PM
โApr-06-2014 04:37 PM
BFL13 wrote:or 10.4F. That's good to know, but it's going to be a long, long time before my panels ever see 10ยฐ.
so unless I lost a decimal place somewhere, that would be 25-37.5 = -12.5C
