Birds nest in AC
joebedford
Nomad II
Nomad II
I finally got around to looking under the shroud of my main AC after the RV has been sitting for over two years with a small hole in the shroud. There was a full birds nest in there with a couple of dead eggs and a dead bird.
Thanks to DW for cleaning it - I'm too heavy for the roof.
I was going to screw a wire cloth screen but the shroud plastic is so brittle it broke where I was drilling my first hole. I taped it up and she reinstalled it. I didn't want to cover any vent holes but that's better than another bird getting in.
I did a quick search and the one place I found with a replacement shroud wants $500 for it. WOW! Maybe there's an RV junkyard with one off a wreck.
11 REPLIES 11
joebedford
Nomad II
Nomad II
This is the birds nest I found in the AC. You can see a couple of dead birds in the pile by my foot (which is the photo for scale).
WinMinnie02
OP do it yourself fill in the holes. Epoxy/caulk, price gouging going on out there.
joebedford
Nomad II
Nomad II
I have a photo to come that shows the birds nest in my RV AC, but my stick house AC quit as well. Look what I found inside:
This mouse nest didn't seem to interfere with operation - there was a burnt wire from the start capacitor. When I replaced that, it worked.
JimBollman
Paid $115 for a new one for my AC a year ago from https://www.rvupgradestore.com
I put chunks of No-Pest Strip in the vents every year because I also had problems with birds and mud dubbers. Not sure if it works but I haven't had any since I started about 4 years ago. I just take the strip out of it's container and cut it in to about .5-1" chunks and push them in the slots around the edges.
BB_TX
MFL wrote:
BB_TX wrote:
What brand? I think $150 +/- is more what the price should be.
Used to be, but like everything else...
Check with PPL motorhomes, for a fair price, and maybe free shipping.
Jerry
Google shows $150-$200 is common price depending on brand.
MFL
Nomad II
Nomad II
Jerry
Dutch_12078
I replaced my brittle A/C shrouds with new ones from ICON Direct. When you find the one that fits your make/model, look for it on Amazon as well. You may find it at a better price.
ICONDirect.com
Dutch
2001 GBM Landau 34' Class A
wa8yxm
Instead of screwing on the protective screen use GOOP or some product like it.
GOOP is a thick gel apply a layer of Goop to the areas you wish to not cover with a solid cover. Press the screen onto the goop (Dampen fingers or glove up as it sticks well to skin) sets in just a few minutes fully sets in 30.
rk911
Colaw RV Salvage. give 'em a call.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
CA_Traveler
Fiberglass the area and drill holes. $500 sounds outragous.
2014 Grand Cherokee Overland
Bob
BB_TX
