Can video stream from USB port on cell phone to TV via HDMI?
rjsurfer
I can use my Chromecast to have streaming video sent to my TV from my phone via it's Hotspot option, no problem, but there is a data limit
on the Hotspot.
Can I stream movies directly through the phone's USB port to the HDMI port via some cable option?
Ron
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
23 REPLIES 23
JaxDad
theoldwizard1 wrote:
HDMI over (wired) USB seems to have died ! You should be able to stream DIRECTLY from the phone to the TV over WiFi with no data charge.
Only if you are 'streaming' prerecorded media from your phone.
If that's the case its likely easier to just put it on a thumb drive and plug that straight into the TV directly.
If it's 'streaming' from somewhere o the internet, data usueage is involved.
MrWizard
Moderator
Moderator
What phone?
The phone spec info, in the manual or online will tell, if the phone has media port capability
But I doubt that will change your data usage
You are still using cellular data to stream the video to your phone
If you have a phone plan that includes video streaming to the phone
Then your allowed data will not be used, when bring cabled connected to the tv
I can explain it to you.
1997 F53 Bounder 36s
MNGeeks61
Depends on the phone. IIRC not all of them can output to HDMI from mini USB/micro-usb. Most Samsung devices can.
Look here:
click
Bessie-Hunter
I can with my Iphone 8 and my Ipad using Apples' Lightning to HDMI adapter.
wa8yxm
YES. I'm not so sure about data quanities but you can get a USB (Phone) to HDMI adapter at most cell stores. Best Buy. Amazon... I may even have one lying about but frankly do not know where.. just google: mobile phone to hdmi adapter
I just did lots and lots of hits.
bighatnohorse
Not if it is an older (non-smart) flat screen TV. Maybe that's part of the question?
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
theoldwizard1
GordonThree
Some phones can, some can't. None of my Motorola phones supported HDMI over the USB connector. My LG did and my current HTC does.
Another option is to use the "cast screen" feature.
With my plan I have unlimited data on my phone but only 15gb on the hotspot. Sounds like you may have a similar plan?
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
Tom_M1
You can, but you will still be using the same amount of data.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
