Capping off a propane line: need tips and tricks!
profdant139
After great effort, I just now found my very slow propane leak (and I will soon prepare a fascinating ๐Ÿ˜‰ report on the many things I learned while trying to find it). Bottom line โ€“ the leak is at the point that the external barbecue fixture connects to the propane system.
What I want to do is remove the barbecue fixture โ€“ we never use it. And I want to cap off the stub or nipple that "tees into" the propane line. The pipe is galvanized. It appears to have an ordinary pipe thread -- not a flared brass gas fitting.
I am planning to unscrew the existing reducing bushing (I think that is what it is called) and replace it with a galvanized cap. I will use teflon gas tape at that joint.
My real question is this: I don't want to put any stress on the other galvanized propane lines underneath the trailer. I will hold back on the galvanized nipple with a pipe wrench while unscrewing the existing reducing bushing. The bushing is very rusty -- I anticipate having to use a lot of force to unscrew it. I'm planning to spray it with WD-40 a day or so before unscrewing it, to try to loosen the threads.
Does this sound like the right approach? I am not a plumbing or propane expert, as you can tell.
Thanks in advance for your suggestions!!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
20 REPLIES 20
MrWizard
Moderator
Moderator
i agree with the pipe dope on a capped line
tape can sometimes be a PITA to use
I can explain it to you.
1997 F53 Bounder 36s
Bobbo
Contrary to popular belief, WD40 is not a penetrating lubricant! Get some PB Blaster. Best stuff on the face of the planet for what you are doing.
On a related note, personally, I prefer pipe dope to PTFE tape.
Bobbo and Lin
MrWizard
Moderator
Moderator
i prefer 'Kroil' or 'PB blaster' much better penetration, bushing will come out easier
I would use a Brass cap, and Yellow Teflon tape is for Gasses, white Teflon is for liquids
Old-Biscuit
YEP....
Always use 2 wrenches
1 to HOLD existing pipe and 1 to use to remove other pipe/nipple etc
Pipe dope the threads (yellow tape will work....several wraps)
Chris_Bryant
Should be black iron, not galvanized, but other than that, itโ€™ll be fine.
-- Chris Bryant
wrktfsh
Thatโ€™s how I would do it. Use pipe dope on the threads. Turn off gas first
