Central Vac went south!
mchero
Had the Dirt Devil Central Vac system in the coach. Just the other day the motor fried rendering the system worthless.
Googled replacement options & found the following;
http://www.centralvacuumstores.com//eureka-cv140-power-unit
Install was a snap and the system as just as much suction if not more. Also, the Eureka is MUCH quieter! Man that old Dirt Devil was a howler!
Note that I reused all attachments.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
3 REPLIES 3
mchero
NP Mex, Get well soon!
Did not want to drop 300/400 on another howler! LOL
Robert McHenry
MEXICOWANDERER
Didn't see it screeching by here.
Must not have come this far south.
Another priceless tip mchero. This goes onto disk. Thank you.
brirene
Can't beat that! Thanks for the review.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
