โSep-04-2018 07:34 AM
โSep-05-2018 05:57 AM
theoldwizard1 wrote:
Model #100302 No sexy looking plastic exterior. Looks like your typical small job site generator. Only about 2 lbs (dry ?) more than the 3400 watt model (it does have a larger engine and fuel tank). Specs say it is a bit louder (64.0?dBA vs 59.0?dBA)
Looking for real world feedback.
โSep-05-2018 04:51 AM
theoldwizard1 wrote:valhalla360 wrote:
You do realize a DB rise of 3 is double the volume...so your contractor's generator will be around 4 times as loud base.
Thanks for your input but I am looking for REAL WORLD feedback !
โSep-04-2018 06:10 PM
troubledwaters wrote:
The Champion #100302 is an Inverter generator.
OP - I have this generator on my shopping list. Just looking for a good excuse so my wife buys into it.
โSep-04-2018 06:07 PM
โSep-04-2018 11:46 AM
โSep-04-2018 09:27 AM
valhalla360 wrote:
You do realize a DB rise of 3 is double the volume...so your contractor's generator will be around 4 times as loud based on the spec you show.
Also are you comparing apples to apples noise specs?
- Check the distance it is estimated at.
- Check the throttle level assumptions.
A good chance the contractor's unit is estimated from a greater distance and at a lower throttle setting.
Then you have fuel economy and power quality:
- If the air/con (or other heavy load) is cycling on and off, the inverter generator will typically use much less fuel because it will throttle way back when the load is off. A traditional generator must keep the RPM up to provide a steady 60hz.
- Related to this, inverter generators generally are better at keeping the 120v-60hz power clean. Traditional generators tend to slow down and the voltage sags when you apply a heavy load before the engine can catch up.
10-15yrs ago, it was pretty much Honda/Yamaha if you wanted a quiet quality inverter generator...today, there are lots of options many much cheaper than the name brand, so going with the contractor type doesn't make a lot of sense.
โSep-04-2018 09:20 AM
valhalla360 wrote:The Champion #100302 is an Inverter generator.
...Then you have fuel economy and power quality:
- Related to this, inverter generators generally are better at keeping the 120v-60hz power clean. Traditional generators tend to slow down and the voltage sags when you apply a heavy load before the engine can catch up...
...so going with the contractor type doesn't make a lot of sense
โSep-04-2018 09:03 AM
โSep-04-2018 08:37 AM
โSep-04-2018 08:33 AM
โSep-04-2018 08:14 AM
