Charge Line on Tow Vehicle Not Working
Daddy_Bear
I have a 2007 Chevy Silverado. Everything on the wiring harness works perfectly except the "Charge Line". It is factory wired and worked last year. I have tested the female plug on the truck and everything works except the charge/power line. Does anyone know if theres a fuse anywhere on the truck that would kill the charge line if the fuse was blown?
Thanks
Drew, Lora & our two boys
Sophie our Toller
2016 Chevy CC, LTZ, LB, W/ Duramax & Allison, B&W Turnover ball and Companion fifth wheel hitch
2015 Grand Design Momentum 328m Toy Hauler
Renology 300W solar
Honda 2000i
5 REPLIES 5
96Bounder30E
Please post any responses here
This duplicate post is now closed
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
Iraqvet05
I had the NBS 2007 Silverado. If I remember correctly, I had to connect the charge wire to stud #1, and supply my own 40a fuse. If you have all that, I believe the truck has to be in tow/haul mode or the lights have to be fully on (not just the DRLs) for that line to be energized.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
dbbls
Don't know about GM but Ford has one under the hood. Check in the owners manual and there should be a description of the location of the fuse box and a sketch showing the location of the fuse and what it controls.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
donn0128
Mod notified
mkirsch
Nomad II
Nomad II
In the fuse box under the hood, there is a 40A fuse labeled "Stud #1" at least on the "Classic" models. Not sure if it's the same on the 2007-2013 body style, but worth a look.
