cleaning up a battery slide out
pianotuna
Nomad III
Nomad III
Hi all,
Any advice on cleaning up a nasty corroded battery slide out on a Class C?
Regards, Don
6 REPLIES 6
accumack
I found some spray stuff at wally world that worked great!
2011 Berkshire 390-rb-40, 2012 upgraded tires and front axle airbags, Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.
westend
Mix the baking soda with boiling hot water. The hotter you get the water, the more the baking soda mix will react with any spilled electrolyte.
You can also make a baking soda paste and allow it to sit on the metal. Over time it will react with the acid residue but the paste needs to remain wet to work.
For repainting, I use a phosphate substitute to clean the metal, rinse, dry, and apply a primer. Sherwin Williams Industrial DTM primer is a good 'un and easily available to the consumer. Top coat with your choice of finish paint. Por 15 and bedcoat liner are both good choices. You want a finish paint that won't scratch through and allow acid to reach the metal.
Good luck with your project!
'03 F-250 4x4 CC
Thunder_Mountai
x2 on the POR15. Just make sure you use plenty of baking soda to kill the acid. Sand, brush or sandblast and follow directions. Expensive, but really good product.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
Twomed
Cleanup then paint with POR15 ๐Ÿ™‚
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Tom_Barb
I completely removed mine, had it sand blasted and powder coated.
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
MrWizard
Moderator
Moderator
i used lots of baking soda and water,
then wire brushed it
next time I'm going to with Mexi's advice and get some "bed liner" coating for it
I can explain it to you.
1997 F53 Bounder 36s
