Cleaning up the mess of battery cables.
Muddydogs
My trailer battery's are a mess of wires, the posts were full from the factory then I added wires for the solar, inverter and others. I was thinking about mounting two of these power posts https://www.bluesea.com/products/category/PowerPost_Connectors/PowerPost to my trailer frame behind the battery's so I could attach all the cables to them then just run one + and - to the battery's. Would sure make checking water levels and getting the box lids on easier.
Good idea? Any other suggestions?
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
17 REPLIES 17
tenbear
Mine came from the factory like this. One #2 wire from the battery, then several different size wires to various things. Seems like a sensible way to wire the battery.
2010 Subaru Impreza Sedan
leeper
I was thinking same as you. My battery terminals are full of cables making a big job of adding water to the batteries. I have to remove the cables and remember where each one goes back to. The power post should work.
