โMay-22-2019 01:22 PM
โJun-07-2019 03:16 PM
MrWizard wrote:
Hot water will lose heat faster than cold water. (It has more heat to lose)
It does not freeze solid any faster than a equal amount of cold water when placed in the freezer at the same time
โJun-07-2019 03:03 PM
โJun-07-2019 01:04 PM
โJun-07-2019 10:32 AM
โJun-07-2019 10:26 AM
โJun-07-2019 10:12 AM
โJun-07-2019 09:39 AM
agesilaus wrote:
If you have tap water that filthy you have other problems in a very big way. You must have been listening to the Culligan adverts, which are as close to lies as they can get away with. I was trained as an environmental engineer if you want to question my expertise. The Culligan adverts lie in other ways, have you ever considered how stupid it is to remove Calcium and magnesium from your drinking water and add Sodium (which is supposedly bad for you). And TAKE Calcium/Magnesium pills at the same time??
โJun-06-2019 10:59 PM
wildtoad
wrote:
Not sure of the point but boiling the water first, will help assure it is safer to drink.
โJun-02-2019 02:18 PM
โMay-23-2019 08:11 PM
โMay-23-2019 06:27 PM
GordonThree wrote:
As I understand it, if you freeze the water in one direction, if gives the gasses room to escape.
See here for one way to do this, he used regular tap water.
clicky
Sorry I'm on my phone, can't make it a click.
โMay-23-2019 12:16 PM
โMay-23-2019 05:14 AM
โMay-22-2019 06:16 PM
agesilaus wrote:rockhillmanor wrote:
Boiling water only kills the bacteria. it won't eliminate the particulates in water. That is what clouds ice cubes, the more cloudy the cubes are the more junk is in your tap water! :B
