โJun-03-2013 09:29 PM
โJun-14-2013 01:05 PM
โJun-14-2013 11:12 AM
โJun-14-2013 08:28 AM
โJun-14-2013 06:16 AM
โJun-13-2013 11:04 PM
jauguston wrote:
Hook them all together. Don't separate them into two banks. It will work just fine.
Jim
โJun-05-2013 04:59 PM
โJun-05-2013 03:44 PM
โJun-05-2013 10:26 AM
McKenziek wrote:HiTech wrote:
The 12v 20 hour rate 160 amp hour batteries I can find are really nice units. I'd be inclined to get 1 or more of the exact same batteries, though they do cost more per amp hour than GC batteries. For example you could add just one more and be at a 480 Ah bank for maybe a little less than replacing the two you have with 4 golf cart batteries to get a smaller bank.
What model number are these big guys? 4D AGM true deep cycles maybe? If they are AGM, it will be hard to get a charger set up that will do what flooded golf cart batteries need AND give the AGMs what they want, without hurting either by under/over charging excessively.
Jim
They are model 27D170's from Harris Battery.http://www.harrisbattery.com/deep-cycle-batteries-harris-deep-cycle-marine-series-27d170
Any comment as to their quality?
โJun-05-2013 07:38 AM
McKenziek wrote:Thanks. ๐ The compartment is steel but I did use two 1/4" pieces of plywood on the bottom of the compartment. Eventually I will probably get someone to weld a steel or aluminum plate on the bottom of the compartment cause I want to get longer slides (I want the batteries to slide all the way out).
Mena, just checked out your sliding battery tray setup. Nice. Did you have to reinforce the compartment below to handle the weight? All my compartments are cheap plastic bins suspended by sheet metal screws so I have some fabrication to do.
McKenziek wrote:Hmmmm. Unless the info in the link is wrong. I would call the manufacturer and see what they say. Should be entertaining.
False Advertising?
โJun-05-2013 05:13 AM
โJun-05-2013 05:11 AM
โJun-05-2013 04:43 AM
โJun-04-2013 09:52 PM
โJun-04-2013 09:39 PM
mena661 wrote:McKenziek wrote:Depends. If the 12V and 6V have the same or similar charging and floating requirements it is probably ok to use the same charger. One of the members here, BFL, says that it was difficult getting his 12V's back to a real 100% versus the 6V's. The 6's were much easier to get back to 100%. IMO, I wouldn't charge them altogether BUT it's probably ok up till the converter goes into float (which is never really 100%), then I'd put them on separate chargers that have the ability to go to 15+V and top them off (Black and Decker VEC1093DBD equalize mode will perform this function).
So would this involve a different Charger? This sounds like a plan as I'm sure the one provided by Thor is some low budget Chinese converter/charger.
