โJun-17-2016 02:56 AM
โJun-18-2016 09:02 PM
Almot wrote:
Brat? You have a talent finding unusual things.
โJun-18-2016 08:31 PM
โJun-18-2016 07:00 PM
Almot wrote:
...Sorry boss, her controller is MPPT.
โJun-18-2016 06:42 PM
CA Traveler wrote:
Holly,
The key for your application (assuming PWM type controller) is that the panels can deliver Isc with good sun. So you'll get 6.1+6.1 = 12.2A maximum to charge the batteries.
โJun-18-2016 04:59 PM
โJun-18-2016 06:51 AM
rjsurfer wrote:
Those Renogy panels are under recall for fire hazard...
Fire hazard !
Ron W
โJun-18-2016 02:37 AM
โJun-17-2016 07:19 PM
โJun-17-2016 07:17 PM
โJun-17-2016 05:54 PM
โJun-17-2016 05:15 PM
Almot wrote:
...Why even consider flexible? (you don't have to answer this ๐ )
โJun-17-2016 04:19 PM
โJun-17-2016 03:31 PM
EsoxLucius wrote:
While all 12 volt nominal solar panels in parallel may be compatible, one of the panels is rated for 19.8 volts and the 17.7 volts. In parallel they will BOTH generate closer to the 17.7 volts.
โJun-17-2016 02:43 PM
