Computer codes
Ckbarger2
My coach is setting codes that state the particulate filter needs to be cleaned. Took it to Cummings repair and they said the filter is fine. They think it is in the chassis harness and it is causing the computer to set bad codes. The coach is in a line mode and will only excel in Econ mode but very slowly. They stated the harness needs to be changed. Trouble with that they don,t make them anymore. Seems to me that there should be someone out there that can ring out the harness and troubleshoot the problem. When we purchased the coach the transfer switch burned up. The seller had someone replace it. Do not know if that could have caused the problem.
3 REPLIES 3
MrWizard
Moderator
Moderator
transfer switch is involved in switching shore power and generator
unless some DC chassis wiring is run thru the same compartment and was damaged by fire/heat
then NO.. the TS has nothing to do with your bad engine codes
I can explain it to you.
1997 F53 Bounder 36s
Vulcanmars
It should be repairable but with what they get per hour a delete kit my be more cost effective.
Give us some more info.
Mars
04 V10 F250 SDCC 4X4
2016 Wildwood 32BHDS
enblethen
What codes is the computer setting?
What chassis and make and model of engine?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
