โJul-26-2018 08:37 PM
โJul-27-2018 01:45 PM
jfeltham wrote:dougrainer wrote:
On Jayco, there is a 30 amp ATC fuse. This fuse is between the Battery and the INSIDE fuse panel. It is located in 2 places depending on the Year Jayco. On a short pigtail within 10 inches of the POS post of the battery. OR, on the front of the trailer ON the cross frame, there is a 4 by 4 metal box and coming out of that box is that 30 amp ATC fuse. IF that fuse is blown(it is) replace it, Your problem is solved. Also, if that fuse is blown, your truck will not charge the battery in transit. Doug
30 amp fuse on POS line is good.
So strange. everything works as it should when connected to 115v.
Shut off 115v and connect the battery, and all 12v stops working whether or not 115v is connected.
Follow-up question...what is the Yellow line on the NEG cable? It has a 35amp in-line fuse. When connected, it gets very warm.
โJul-27-2018 09:35 AM
MrWizard wrote:My guess (since we're all guessing here) would be both of those black wires go to different devices (like slide motor & tongue jack, for instance) and both devices are grounded to the frame; hence both black wires would go to the Positive batt terminal.
Trace the two wires is where they go
If I had to make an emg guess
Fused wired positive
Other one ground/neg
โJul-27-2018 09:32 AM
CA Traveler wrote:x2. To others reading this, please do that. You will not remember which wires go where.
Lesson learned? Mark all wiring and take pictures before disconnecting.
โJul-27-2018 09:13 AM
โJul-27-2018 09:09 AM
โJul-27-2018 08:59 AM
โJul-27-2018 08:45 AM
โJul-27-2018 08:10 AM
โJul-27-2018 07:30 AM
โJul-27-2018 07:24 AM
2oldman wrote:jfeltham wrote:Shouldn't have to. Your browser should.
On the road and I can't remember my sign in credentials...
โJul-27-2018 07:03 AM
โJul-27-2018 05:00 AM
โJul-27-2018 03:29 AM
jfeltham wrote:
Could an electrical problem with the trailer battery pull down the tow-vehicle battery?
โJul-26-2018 09:45 PM
