โJan-12-2014 10:14 AM
โMar-02-2014 11:12 AM
โMar-02-2014 07:58 AM
โMar-01-2014 12:06 PM
alphamorph wrote:
Thankyou all. WA8 makes a good point as mine is the 80amp model BUT by 'surge', I mean the generator doesn't only rev up; it oscillates up and down in revs after an brief, initial high rev. It is becoming clear that the batteries are getting long in the tooth and when low in charge, the smart wizard on the converter is sending high and medium charges to the batteries which in turn causes the econo throttle to attempt to accommodate. I will install a couple of new batteries and after initial charge up, drain them half way down and test my theory. Will let you know findings.
โMar-01-2014 11:43 AM
โMar-01-2014 11:04 AM
โMar-01-2014 09:39 AM
โFeb-28-2014 02:23 PM
โFeb-28-2014 02:10 PM
alphamorph wrote:Can you correct the condition by setting the choke on slightly?
Thanks for the reply MM49. Why would this occur now (after 4 years)with the old generator and setup. I would be quick to agree if it was only happening with the new generator but both generators are reacting identically when I throw the switch and connect the batteries..... BUT, the problem seems to be overcome if the generator is allowed to run for about 15 or 20 minutes and then connected to the batteries.... so you may have something. It's just that they run so well otherwise, even under very heavy loads.
โFeb-28-2014 10:04 AM
โFeb-28-2014 09:57 AM
โFeb-28-2014 07:11 AM
โFeb-27-2014 03:13 PM
โFeb-27-2014 02:41 PM
โFeb-26-2014 09:31 AM
