โMar-16-2021 08:29 AM
โMar-16-2021 11:34 AM
โMar-16-2021 11:16 AM
โMar-16-2021 10:48 AM
time2roll wrote:
The only trouble with PowerMax is the short absorption time. With 55+ amps the converter will hit the 14.6 volts fairly quick and then you get maybe 15 to 30 minutes at that voltage and you are only about 80% charged when the voltage drops to 13.6.
For a single battery deck mount I recommend the BD 1235CL at just 35 amps. This will get you closer to 90+% charged before the voltage drops. Or go with the PD9245 or PD9260 that will hold the boost voltage a full 4 hours.
โMar-16-2021 10:36 AM
โMar-16-2021 10:23 AM
morley wrote:klutchdust wrote:
Best Converter without a doubt. Plug and play, excellent customer service . Call them, tell them what you need. fixed my issues with my batteries boiling in my Class C.
Totally agree Best Converter is the way to go, very simple lower portion replacement of your WFCO. Did it myself and it works well. Randy at Best is the โBestโ very helpful and will answer all of your questions if you have any. No more boiled batteries for me now also.
โMar-16-2021 10:09 AM
โMar-16-2021 10:07 AM
BFL13 wrote:
A single 27 will accept about 45 amps at 50% SOC and taper almost right away for its Absorption Stage. If you hit it with 60 amps all that happens is the amps will immediately drop to whatever the 27 will accept and taper from there.
That's with a flooded battery--don't do that with AGM or Si02--stick with their 27% charging limits--ie 27 amps on a 100AH batt or you can use your 55 amper on a pair of 100s. LFP can take it though.
ISTR a Honda 2000 spec is 13.3 amps at 120v for running output of 1600w (VA really)
I prefer the PowerMax line (same as Boondocker, a rebadged PowerMax) but the PD with Charge Wizard might be easier to operate if you are not ready to do manual voltage adjustments to suit your battery specs. (or you can chose the standard three-stage automatic mode if on shore power) If you are on shore power it doesn't matter about which converters--they all do about the same Float voltage.
Most converters at 75 amps and below are not power-factor corrected and their PFs are about 0.7, so you have to add that to what the generator will have to supply.
EG, as measured with a Trimetric and a Kill-A-Watt here is how it works for a 55 amp converter with battery accepting 56.8 amps and rising through 13.7 volts. (3000w Honda generator)
124.7 v, 11.06 a, 980w, 0.7PF, 1380VA (Kill-A-Watt )
So the Honda 1600 VA would supply that 1380VA. Same deal with a 75 amp converter needs the gen supplying 1700 VA, so the Honda 2000 would be a little overloaded. The Honda 2200 is rated for 1800VA though, so that would be ok with a 75 amper.
My B&S P2200 just barely runs my 75 amp converter which pulls 1700VA and the gen is rated at 1700VA.
You have a choice if the WFCO does run of leaving it in place and get a deck mount converter to work with the gen, or else replace the WFCO "lower portion" with a better converter.
โMar-16-2021 09:41 AM
โMar-16-2021 09:27 AM
โMar-16-2021 09:25 AM
โMar-16-2021 09:19 AM
โMar-16-2021 09:11 AM
โMar-16-2021 09:08 AM
pulpwood007 wrote:The spec plate on the eu2000 should say 13.2.
My calculation shows about 16 amps AC available from the generator. .
โMar-16-2021 08:58 AM
2oldman wrote:pulpwood007 wrote:Perhaps a little electrical education is in order.
My calculation shows about 16 amps AC available from the generator. I can't decide if I can safely go with the 55 or 60 watt converter and not overload the EU2000??.
I think you mean 55 or 60 amp converter. And that's at 13+ volts, so it's not equivalent to 16amps at 120v. 60a x 13v = 780 watts so your 2000+ watt generator will be fine.
A few lights is virtually no load at all.
