Well not all RV's play nice with GFCI outlets..
Some the converter seems to be the issue if the batteries are "Hungry"
Some if the batteries are "Full"
Some it seems not to matter
Some it's not the converter.
There is a whole list of "Suspects"
Start by turning off all breakers in RV
Plug the RV into a GFCI outlet and plug a drop cord (Trouble lamp) into the other half of that GFCI protected outlet
Now put the lamp where you can see it inside the RV
Turn on the main, Lamp still on good
Turn a branch circuit, and another and another till the light goes out.
NOTE THAt one . turn off, reset GFCI and continue till all breakers are either ON or NOTED.. now you have a suspect list (What that breaker powers)
