Dead Onan 4000 generator
DouglasC
Went to fire up my Onan 4000 generator for the 1st time this year. Held the Start/Prime switch down on Prime and the light came on and flashed like usual. After about 5 seconds I released the switch as usual and pushed the Start side of the switch. Nothing happened - - totally dead. Tried the Prime side of switch again - - nothing happened. Last time this happened (generator dead) 7 years ago the cause was a faulty circuit board that needed to be replaced.
Anything else I should be checking before I order a new circuit board?
Doug
2006 Jayco Greyhawk Model 27DS
Towing 2019 Ford Fusion Energi with Brake Buddy
23 REPLIES 23
DrewE
Have you checked the 12V fuse on the generator? It's an easy, low-hanging fruit sort of check. Checking that all the connectors in the guts of the generator (through the firewall) are clean and tight is also worth checking/trying.
DouglasC
Ranger Smith wrote:
DouglasC wrote:
Apparently I do have 12 VDC at the generator because the light came on when I 1st went to Prime the generator. But I will definitely check to make sure that there is 12VDC at the generator before I order a new circuit board.
I just reconnected all the battery cables to the coach batteries before attempting to start the generator so the connections are all clean.
The light may come on even if there is 10 or 11 volts. It will not turn over unless it sees a certain voltage or greater. Don’t assume by the light coming on . Measure it at terminals where it goes into generator. There is also a relay under the enclosure that is a start relay that goes bad. They can be purchased at an auto parts store. How do i know... been there done that
OK - - I tested the voltage coming into the generator - - 12.9 VDC. If the problem was only a bad starter relay, why wouldn't the primer still work? I'm still leaning toward a bad circuit board since nothing works - - the generator appears to be dead!
Doug
DouglasC
bukhrn wrote:
I assume you are trying the remote switch in the house, have you tried the switch on the generator it's self?
Yes, I have been tried the switch on the generator after the remote switch failed to work in starting it. No luck there either.
Doug
bukhrn
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
ajriding
Yes, clean. Use a battery cleaning agent (do internet search for how to clean) on terminals and any electrical connection. It is amazing how two metals can touch, look clean, yet not conduct electricity. Start here, this is free.
Ranger_Smith
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
DouglasC
Doug
Old-Biscuit
Do you have 12VDC at the generator?
madjack60
I had the same problem with my onan 6500. I cleaned the battery cable connection at the battery and all was good. What threw me off is all the coach lights worked but the gen was dead.
