Decals on front of TT
Louie___Eva
Our decals are peeling off of the front of our TT. We need to take them off so that we can replace them. What is the best way to get them off?
Montana 2008 Mountaineer travel trailer 32FLD
2006 Ford F350 PSD, Lariat, CC, LB, SRW and Blue ox sway control
6 REPLIES 6
phenrichs
I would not use a chemical on my fiberglass TT. A friend of mine works for a vinyl graphics place that does vehicle wraps and they use heat and the wheel.
2006 Ram 3500 Megacab Cummins
2012 Keystone Sprinter 311BHS
Ron3rd
I used a heat gun along with a plastic putty scraper when I removed mine. Be careful not to get things too hot. You'll need to remove the left over glue too. The glue can be as big of a PITA as the decals. I removed the glue with plain old gasoline on a rag on the suggestion of a member of this forum and it worked great.
This was on an aluminum sided trailer.
Equilizer Hitch
Honda EU2000
Dick_B
Previous discussion. Search this Forum for `decals' then search the results for `3m'
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
96Bounder30E
Moved from DIY
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
harold1946
A 3M eraser wheel works great. Some use a heat gun and peel it off.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
tanman32225
Use a heat gun.
