doug richards wrote:
anyone got any ideas
2001 travelaire super slide, that doesn't slide (out ) so easy...goes a short distance then slows almost to a stop...then there is sort of a bump....may completely stop/ or may pick up back to where it should be....ideas?
The big slide on our 2003 has been getting hard to come in the last few years and I did all the lubrication things but still no luck.
This year I got at the electric side of things and worked through the whole thing eliminating suspects. Thank goodness the motor was ok! Those cost about $550. Anyway it was two things.
-the slide out rocker switch was "tired" and a new switch made a big difference. I guess the contacts inside the old switch were getting poor.
- the input to the slide out switch has neg and pos from the battery but the neg side was via the frame. The frame contact point was corroded, so I cleaned that all up and got good contact there again.
Now the slide goes in and out like when the trailer was new. Of course it is still lubricated underneath in the gears (dry spray lube ) too, but not sure it needed that.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
