Did I just do a stupid thing with my fan install?
Naio
I don't know what's wrong with me, but somehow in rereading the fan install thread,-- after a month away working on a rental property -- I missed the butyl tape part.
Could not get an AC gasket for reasonable price, so made one out of an old truck inner tube, layered that with dicor so it goes fiberglass, dicor, rubber, dicor, fan flange.
Is this ok or am I an idiot?
I did check that my dicor was ok with rubber and fg.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
13 REPLIES 13
MEXICOWANDERER
HE, is a very sweet lady. And those who mock quests for knowledge have a sad lot in life. Very high on the arrogance meter. What a shame.
ScottG
LOL
dougrainer
ScottG wrote:
mike-s wrote:
dougrainer wrote:
$16 for a roof AC gasket is price gouging????????????????????? For $16 you rigged something up? WHO uses a AC gasket for a Fan install???? NOBODY in their right mind. Doug
That's harsh. He was doing what he thought was right. And it was right for the primary need - there shouldn't be any leaking issues. Just a lot of work (or more probably, a larger area which needs sealing) the next time the fan has to come out, which hopefully is in a long, long while.
Yeah, it's garbage posts like that that inspired me to block him long ago.
The poster ASKED the question. Is he an Idiot? I did not state he was, but pointed out he did not use common sense when he installed the fan. NOT a Garbage post. I am sometimes VERY blunt, but I do not post garbage. Block me? Get a life. Doug
ScottG
mike-s
dougrainer
Naio
Oh, thanks, youse guys :).
I did dicor the edge.
And then, next job, I removed a leaking window, saw what the butyl is like. Yeah, that looks like good stuff and removeable!
I sure hope I never need to remove that fan...
BFL13
You forgot to add Eternabond on top of all that! ๐Ÿ™‚
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Lwiddis
Inner tubes can last for years on a tire. Protected from sun...I think it will work.
mike-s
The reason to use butyl tape is because Dicor will end up gluing things down, which makes it very difficult to remove them in the future. Dicor is a LAP sealant, i.e. it's made to cover the top of a joint.
ScottG
Not at all. The Dicor will do the job just fine - there's no reason to use anything else. You didn't even need to make the gasket.
I installed two FF on our last TT with just dicor (didn't use the flimsy bubble wrap "gasket" they provided) and it was still water tight 13 years later.
On our new trailer they were installed by the factory the same way, just Dicor.
I would cover the edge of the inner-tube material with Dicor because it will brake down with UV if you dont protect it.
time2roll
wa8yxm
Two answers.
1: If it leaks in the first rain you experience... YES you are an idiot.
However
2: IF it works.. NO you are an engineer and that is what I think you are.
