โAug-31-2016 03:41 PM
โSep-04-2016 08:14 AM
GoPackGo wrote:NinerBikes wrote:MudChucker wrote:The "deicing" additives in what could be called "winter formula" are the same additives that keep moisture out of your fuel tank, put it in suspension in the fuel, and allow all of it to go through your fuel system safely and out your tail pipe.JimBollman wrote:The Works wrote:
We started a 6 month work kamper job Mount Pleasant South Carolina.
He is going to be in SC, he doesn't need Winter treatment.
You are correct 'ish...
Winter additives are usually better at dealing with condensation and water in the tank.
Just because it is labeled winter deicing formula does not mean that it is restricted to winter use only. Anyone in hot humid climates should run the stuff with their fuel from time to time to keep their fuel dry. And consider it preventative maintenance with a full tank of fuel if you put your RV into storage.
I've never heard of winter deicing formula diesel. It really sounds like you are describing winter blend gasoline.
Summer diesel is straight #2. Straight #2 diesel will start to jell when temperatures drop below about 20 degrees. Winter blend diesel is formulated to resist jelling when temps drop below the magic 20 degree mark, which is the point where wax will start to form and clog fuel filters - and stopping you dead in your tracks until your vehicle can be towed into a nice warm garage (ask me how I know).
There are two ways to formulate winter blend diesel - either add chemicals that lower the jell point or add a percentage of #1 diesel (#1 resists jelling to much lower temps). The 'mix' changes as the calendar moves farther into the winter season - less chemicals or #1 in Nov/Dec and more in Jan/Feb. In my experience, cutting #2 diesel with #1 works much better then going the chemicals route.
#1 diesel has far less lubrication qualities then does #2 and also less BTUs (less power and MPG). Keep in mind that your REALLY expensive engine high pressure fuel pump is lubricated only by diesel fuel and you'll understand why it's not a good idea to run #1 diesel in the summer.
** On edit - I've read this about 3 times and I now see that the above post is more about additives then the fuel itself. I think if the tank is full, then there will be no condensation problem. If there is, it will settle to the bottom and you can then drain it from your filters. Pleasure boaters with large diesel tanks in their boats store fuel over the winter and then go merrily on their way in the spring with no problems. Just not a big deal. If we were discussing ethanol based gasoline (ethanol will attract water). I would definitely recommend some type of additive. My comments regarding summer and winter blend diesel are still valid.
โSep-03-2016 11:20 AM
โSep-03-2016 09:53 AM
โSep-03-2016 09:40 AM
MEXICOWANDERER wrote:
I like to see the slimy snot slopping in the transparent settling bowl of my RAcor filter. A twist of the wrist and adios booger-water.
โSep-02-2016 12:43 PM
โSep-02-2016 10:40 AM
โSep-02-2016 10:27 AM
โSep-02-2016 08:04 AM
MudChucker wrote:
jeebuz, I cant believe the "facts" that some are pulling out of their hats here.
Just stop, seriously, I have never seen the internet provide so much bad advice as I have in this thread.
even if the odds are 50/50, a few minutes to fill a fuel tank and add 15 dollars worth of additives could save the OP thousands of dollars.
โSep-02-2016 06:41 AM
โSep-02-2016 04:58 AM
โSep-01-2016 05:54 PM
โSep-01-2016 03:08 PM
MudChucker wrote:
Fill the tank. Treat with winter fuel treatment.
โSep-01-2016 08:21 AM
wolfe10 wrote:
Totally agree. If something is going to grow in the tank, it did come from an external source.
But, not that hard to imagine that at least ONE station you fueled up over the last year or two DID have a contamination issue.
