dimensions yamaha 3000 inverter generator battery
pianotuna
Nomad III
Nomad III
Hi,
Does anyone know the dimensions of the Yamaha 3000 iSEB battery? The weather in Florida "ate" mine and I'm beating my way back to Canada.
Regards, Don
5 REPLIES 5
pianotuna
Nomad III
Nomad III
Hi Matt,
The battery is not totally dead--but it only goes "click" when I turn the key. I solved the issue on the trip back north by getting a "jump pack".
The last Walmart I stopped at had a battery whose dimensions fit the Yamaha.
Regards, Don
MattFL
pianotuna wrote:
Hi,
Did you run your generator without the battery for any length of time, and did it cause any trouble if you did? I've got the same generator with a bad battery and trying to determine if it's OK (won't cause damage) to run without it.
ScottG
pianotuna wrote:
Hi Scott,
Thank you!
:C
pianotuna
Nomad III
Nomad III
Hi Scott,
Thank you!
Regards, Don
ScottG
Here's one for sale with the dims in the description:
