โMay-21-2015 07:13 AM
โMay-21-2015 08:47 AM
โMay-21-2015 08:37 AM
jrnymn7 wrote:
Venting from the side wall would work fine... mine does, and so do hundreds of thousands of other rv's. And you could, theoretically, end up drawing trapped exhaust pipe heated air up thru the cabinet.
But yes, the fuel filler is a logistics/safety issue, for sure. Any way you can install the fridge away from that area?
โMay-21-2015 08:22 AM
โMay-21-2015 08:12 AM
ScottG wrote:
It looks like the back of the fridge is too far from the wall. The installation instructions want the back of the fridge within something like 1/2 to 1" (check instructions). Otherwise the flow of air may go around the tubes rather than through them.
Also, since the top vent has to go around a corner, I would add a fan.
jrnymn7 wrote:
Why not make that 12" x 12" access door a vent, instead? These work well, and are screened:
soffit vent
They come in aluminum, white and brown.
You could even hinge it on the bottom, and have 4 screws along the top. And put some 1/8" x 1/2" foam gasket in behind to keep the rain out.
I have several of these on my minibus conversion. I cut them to size... one, two, or three sections.
Two of those fans should be plenty... and only required during hot weather.
TakingThe5th wrote:
There are current installations in RVs that do use a fan(s) to dissipate heat from the back of the unit. My installation uses a thermal switch to control the fan in the back.
โMay-21-2015 07:28 AM
โMay-21-2015 07:26 AM
โMay-21-2015 07:25 AM
