Do the math for me...
eric1514
...and then tell me how you did it.
I have an appliance that is rated 130 watts at 110 volts (house current). How many amps per hour will this appliance draw from a 12 volt battery?
TIA
Eric
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
23 REPLIES 23
time2roll
130w 110v resistive load might still draw 1 or 2 amps from a 12v battery.
Almot
allen8106 wrote:
Wrong...It's 130 รท 110 = 1.18 amps
The question was "from 12V battery". Therefore, about 12-13 amps with inverter losses.
Hooked up straight to 12V, AC appliance will draw nothing, of course ๐Ÿ™‚
_40Fan
0. Plug it into 110.
2013 Arctic Fox 22GQ
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
Kayteg1
Since you are running 120V appliance from 12v battery, you will need inverter.
Depends on quality, those will take additional +- 10%
As you can see those can be only approximate numbers.
We don't know if the voltage is 120 or 110 volts.
Nor 12 or 12.5 volts
allen8106
smkettner wrote:
130 รท 10 = 13 amps
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
eric1514
Thanks to all!
Eric
420 Ah batteries
400w Solar
time2roll
red31
130.000 watts / 12.0000 volts yields amps, you do the math.
divide by .8 or .9 for inverter effiency
2oldman
130w /110 = 1.18 amps (Rule: Watts= amps x volts)
Battery draw at 12v is approx. 10x what the 110v side draws, therefore, 10x 1.18=11.8 amps. (Rule: watts are conserved. Voltage is 1/10 of 120, so amps must be 10x)
And it's not "amps per hour", it's just amps. If you ran it for one hour, that's 11.8 amp-hours.
