Domestic electric water heaters
theoldwizard1
Your typical gas or gas/electrical RV water heater seems to be the source of a lot of "heartburn" for many people ! Seeing as most people do NOT boondock (or only occasionally) has anyone considered switching to a domestic hot water heater ?
Westinghouse makes a 10 gallon stainless steel 10 Gal. 1440 Watt water heater. It probably will not fit in the same space as your current water heater and it will take more than 1 hour to heat a full tank, but it should be hassle free. Most 2000W generators should be able to run it.
20 REPLIES 20
jdc1
My gas/electric water heater is 21 years old. Still works great.
Ron3rd
BB_TX wrote:
Suburban and Atwood have both proven to be very good and highly reliable water heaters. Yes, there are instances of some issues. But a small percentage I think. My 13 yr old Suburban still works fine. I don’t see need to complicate the issue with something that may have its own problems in addition to a custom installation.
Same here. I've had zero issues with the water heater in my last two trailers. No reason to consider an alternative.
Equilizer Hitch
Honda EU2000
theoldwizard1
Good to get positive feedback !
My daughter's Attwood never has run right since the first day the bought their Jayco. It would light once, but almost never re-light until you cycled the power switch. 3 trips back to the dealer and over $100 out of pocket for "igniter adjustment" and they gave up. If they want hot water, they have to keep cycling the power switch.
Very strange.
Old-Biscuit
Few folks post Positive things cause not a problem
Negative posts are looking for HELP therefore it SEEMS like lots of troublesome water heaters, furnaces, water pumps, fill valves, fridges, AAVs, ATS, etc etc etc
My 13 year water heater, furnace, fridge, etc are OEM and no parts replaced
Did have ATS issue.....solved that with a manual transfer switch
And did replace both AAVs cause OEM were cheap
time2roll
There are plenty of RV propane/electric water heaters available in 10 gallons.
Mine runs fine 15+ years now.
BB_TX
