Dometic refrigerator at higher altitudes
hshea
We purchased a new Keystone TT last year at the RV show here in Denver to replace our 10 yr old Forest River that never had an issue in its life. Now Denver is at 5280 feet and we camp in Colorado at National Forest campgrounds that usually do not have hook ups are all above 5280 ft. The Dometic fridge hardly works on propane it tries to ignite and fails to ignite 99% of the time, we have been to 5 dealers and spent nearly $800 of our own money and it still doesn't work. Now Dometic is telling us that their new fridges will not work above 5,000 feet. Why are dealers in Denver selling a TT with a fridge that only works at sea level? We are so frustrated and sad we sold our old Forest River - needless to say Keystone doesn't give a darn and Dometic say there are no fixes for altitude so we have a $30k travel trailer and have to use a cooler? Has anyone else had this issue and found a work around?
7 REPLIES 7
Rvpapa
Set LP regulator down to around 10" W/C. BTDT
Art.
grizzzman
The three Fridge's I have been dealing with are suffering from "flame lift" at start up durring coldish weather. During start up the flame lifts off of the burner. The lift off lasts for about a minute(ish) The problem is the igniter is also the flame sensor. When the flame lift's off there is no path to ground. The unit believes that there is no burn and shut's the propane off. To get around this issue I install a copper ground probe from the burner parallel with the igniter, this allow's the sensor to "see" the lifted flame untell it settle's down. This mod worked well at 9100 feet on all three units. (The regulator's were adjusted to 11 water column's prior to the mod)
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH Hybrid. ElectroDacus. Renolagy DC to DC charger. 2000 Watt Inverter.
Boondocking is my Deal
joshuajim
First, I would check the wc pressure to see if it's at 11". Could be a bad or mis-adjusted regulator.
RVing since 1995.
1492
Moderator
Moderator
Moved from Forum Technical Support
Sandia_Man
That stinks, our Dometic is the same model as yours and works perfectly at high altitudes. We also live at the same elevation here in Albuquerque and 80 percent of our camping is at 7K"-9K' elevation and fridge operates fine whether on 120vac or propane. Here's hoping you get it worked out, something in not right on your unit or these forums would be bombarded with this issue. I know plenty of RVers who primarily camp at higher elevations, some with new rigs as well not having any issues as you described.
MWJones
I find it hard to believe (Dometic won't work above 5000 ft). Mine works fine at 8000ft at South Fork Co.
You have gotten some BAD info!!! Talk to a Lawyer. Sue for a new refer and fee's.
M Jones
American and Texan by birth
Christian by the Grace of God
Retired and enjoying Traveling and Camping
Spending part of summers in South Fork, Co
MWJones
M Jones
